Have you installed DRM brake ducts on a C5? C'mon in...
So I'm installing my DRM brake ducts and have the OE Corvette ducts cut per instructions and the ID's of both the DRM duct and the OE ducts are the same! If you've done this job you know the OE ductwork, once cut, is supposed to slip into the end of the DRM duct and is secured with a couple of sheet metal screws, making a clean, quality install. Not on my parts!
I have considered that I may have the OE ducts a bit too long, although they measure 10 1/2" like the instructions call for. I was thinking perhaps the duct narrows a bit and that would allow the OE. ducts to slip into the DRM duct, but my calipers don't show it.
Talk to me... is this common? If this turns into a butt seam secured by duct tape...well I could have done that with the uncut OE ducts and 3" hose. I was looking for a quality install.
The image below shows the dilemma...the cut is on the left of the blue tape and the DRM duct is obviously on the right. Am I missing something?
Received 8,928 Likes
Bill
It looks like it's gonna be a very tight squeeze even with the OE duct slit as you suggest. I was hoping there was a better answer....LOL. Thanks for your input Bill.
NC Events Coordinator
It seems like you could remove a little material from the outside of the smaller-diameter piece with a belt sander and the inside of the larger piece with a Dremel or spindle sander if you have access to one.
Is that possible?
Is that possible?
Had the same problem several years ago when I did my install. Just make 2 small slits, remove about 1/8" of material and slide one inside the other. Secure with sheetmetal screws and a final wrap with duct tape. It will stay in place and work fine.
...except use Gorilla tape. It's going absolutely nowhere. That stuff is legit.
Why they weren't made with a larger ID to slide over without the drama, I have no idea. Maybe a future improvement.
Okay gentlemen, thank you all for validating my install concerns. Slit, tape and screw it will be. Makes my **** side a bit crazy but I'm sure it will work fine.
Received 1,254 Likes
2016 C5 of Year Finalist
I spent too much time on this system and gave up. I run electric
blowers on the front . The biggest problem was finding a place for
the blowers. I am just like the Nascar guys---well sort of..........
Finished the install today. Like others have done, I slit each OE duct about 3" at 180 degree positions along the mold seam and used my cutoff wheel to open the slits about 1/8". This was enough to allow the OE ducts to slip into the DRM ducting. Not s great fit but good enough. I used two sheetmetal screws to hold the ducts in place per DRM instructions and then wrapped the seam with Gorilla tape. Worked okay, but DRM needs to address the incorrect ID on their ducting.
Gorilla tape OTOH works great and is far more professional looking than mere duct tape. I'll never use duct tape on this type of application again. Great tip!
