Hoosier Tire Life
Hoosier Tire Life
If I am considering running my C5 Z06 in an enduro, how bad is tire wear on a set of DOT Hoosiers? How many hours can I expect to get out of them?
Brakes as well?
Brakes as well?
Which compound are you going to run - A or R ?? Big difference in life between the two with R's giving more life. I used to run the R compound and got 5-6 weekends out of them running 5-8 30 minute sessions a weekend. Same life expectancy for front pads running Wilwood calipers and H compound. It really all depends on the length of the enduro, the track you are going to run on and your braking style.
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
Then again, the concrete is pretty brutal on tires, and we turn a whole lot more in 1 lap. On our 1-mile course you're looking at 60-70 turns.
I will be running 12-13 hour enduros, maybe a few shorter ones in the 4 hour range.
I will be running R compound for sure.
Brakes are stock as of now. Coming from Spec Miata racing, my braking style is, don't use the brakes and carry momentum. I have tracked the Vette and used the approach with great success.
I usually run Hawk Blues in the Miata which will last a full 12 hours. I have heard of Corvettes running the Hawk HPS pads, but would like to hear feedback from everyone.
So the questions are, what tire and how many sets will I need?
What brake pads, and can I make it on one set?
Cruising
We ran a 3 hour Enduro last year at NJMP Thunderbolt in a '99 FRC ST2 car. It was a last minute decision so all we had to work with was 2 315/30-18 R6's on the front (they had roughly 20 laps on them before the enduro) and 2 315/30-18 A6's for the rear (new). At the end of the race, the A6's were corded and the R6's looked OK - they probably would have gone another hour at the most. Hope this helps
Supporting Vendor
St. Jude Donor '11,'13
With those tires I would run XP24 front and XP10 rear.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
