Anyone Ever Program a New BCM?
I've got a 2007 C6 Z06 with a bad BCM. Installed one I had in my garage which had the correct part number, had it programmed at the dealer and everything was fine except for Service Active Handling and Service Ride Control messages. The dealer suggested a brand new BCM and another round of programming. I installed a new BCM and get Shift to Park along with the Service Ride Control messages and others. It also won't allow me to put the car in competition mode.
My question is when I go to get this new BCM programmed is there anything specifically I should request? Does the programming use the year, the VIN or specific option codes. I just want to be as knowledgeable as possible when I go back to the dealer and make sure it gets programmed correctly this time. Thanks for any help.
We have to use our Tech 2 to reconfigure the options that are on the vehicle ( the setup of BCM is an option on the Tech 2) As long as they configure the BCM properly (with the Tech 2) you should be good to go.
So do all the option codes listed in the glove box need to be input during the programming and do you know specifically which one eliminates the ride control message? Thanks!
[QUOTE=mcar00;1585456703]So do all the option codes listed in the glove box need to be input during the programming and do you know specifically which one eliminates the ride control message? Thanks![/
When the technician programs the BCM, there will be questions asked as to which option codes are on your car and he will select the options from a drop down menu on the PC about the options that are on your car. As long as he selects the options that are on your car at this time, everything should work properly.
I had to do this for my 06 Z. You have to buy a fresh BCM and the dealer has to program it with the Tech2 for a number of reasons. One, so the options on your car will actually work. They have to flash in the VIN number as that's a one time only write option. If the VIN isn't correct on the BCM, you can have issues with the theft system and the radio/NAV as they are VIN tagged as well. You can also have SRS error codes...a whole litany of things will pop up.
Once I had the dealer flash the new BCM, I have been good to go and that was 4 years ago.
