DRM Monoballs, LG Drop Spindles and Baer bumpsteer kit...
Old 11-17-2013, 08:57 PM
Gman57
Gman57's Avatar
Default DRM Monoballs, LG Drop Spindles and Baer bumpsteer kit...
DRM Monoballs, LG Drop Spindles and Baer Bumpsteer kit...
Installed and ready to go. Lowered car by 3/4" with .6 more camber in the front and .2 in the rear. This should make a big difference both in the corners and tire management
Just shy of 4" off the ground..... Now getting it on the trailer might be the trick
Old 11-17-2013, 10:57 PM
phxcobra
phxcobra's Avatar
Sexy
Old 11-18-2013, 10:31 AM
SDF
SDF's Avatar
Awesome car Gary! You definitely have something to be proud of!!! Catch you later..............
Old 11-18-2013, 10:57 AM
Lawdogg
Lawdogg's Avatar
Hey Gary,
You have a first class setup! I'm probably doing monoballs this winter too. I have a picture of my car from MAM where you can see the poly bushing flex. My camber is set at -3.2 in the front and -1.7 in the rear. In the picture the camber in a corner looks to be closer to 0 degrees than -3.2 and -1.7 because of compression of the poly bushing. With monoballs, I'd probably be able to back the negative camber off a little (would help with the wear of my street tire setup).
Old 11-18-2013, 12:00 PM
froggy47
froggy47's Avatar
The heim's that are included with the bumpsteer kit are poop. Unless they upgraded them. Check them for play ever session. I tossed mine & put qa1's (aurora good also).
Old 11-18-2013, 02:33 PM
Gman57
Gman57's Avatar
Originally Posted by Lawdogg
Hey Gary,
I was at 2.4 front & 1.3 rear now with 3.0 and 1.5 should make a huge difference
Hope to see you at a few of the Central Region events next year!!
Old 11-18-2013, 03:59 PM
Lawdogg
Lawdogg's Avatar
I'm hoping we will still have MAM events!
If I had a track only car like yours with monoballs I would run about the same camber you now have. On my dual use car, with monoballs I'm hoping to dial the camber back to 2.2 front and 1.3 or so rear and still get reasonable stick and wear out of my track tires and reasonable wear out of my street set up. I guess we'll see.
Old 11-18-2013, 05:15 PM
oversteer
oversteer's Avatar
What a beauty - nice build
What brake kit is that? Looks like Alcon or PFC?
Would you mind sharing your wheel and tire specs?
Old 11-18-2013, 06:29 PM
Gman57
Gman57's Avatar
Alcon BBK with DRM adjustable master. 18x13- 345's & 18x11- 315's
Old 11-18-2013, 09:02 PM
krisa9977
krisa9977's Avatar
I've got almost the same set up. TIKT Monoballs, LG Drop Spindles, custom valved Bilstein dumpers and GT1 aero. Will be testing this car on December 7 at Road Atlanta. I'm setting up my car about 3 inch high in front.
Old 11-18-2013, 09:54 PM
Lawdogg
Lawdogg's Avatar
I've seen the Tikt monoballs on their website. Unfortunately, I can't read German. Can you give me some details on their monoball setup. Cost, how do they install (press fit, glue?), and what is your opinion of their product. Thanks!!!
Old 11-19-2013, 12:09 AM
5280Racer
5280Racer's Avatar
Looks killer.. Hopefully we can battle it out at High Plains next summer.!!!
You still have the black and red forge lines??
Old 11-19-2013, 12:27 AM
yooper
Support Corvetteforum!
yooper's Avatar
Interested as well.
Old 11-19-2013, 09:44 AM
Gman57
Gman57's Avatar
Yep I really like the Forgelines too
Old 11-19-2013, 09:54 AM
krisa9977
krisa9977's Avatar
Never tried TIKT yet(just bought them), but it looks like is top of the line product. Is far as I understood they use German made top quality bearings same as for GT3 cars.
Old 11-19-2013, 10:39 AM
rabrooks
rabrooks's Avatar
How much does a complete set of Monoballs cost. Do they transfer any extra vibration into the feel of the car.
I can only get 2.2 neg. camber in front with stock setup. If the pressures and temps are not just right, my car pushes badly. When conditions are right it handles ok. I would like to loosen it up a bit.
Roger
Old 11-19-2013, 11:21 AM
krisa9977
krisa9977's Avatar
It is about 2000 euro in Germany. If you worry about vibrations, you probably don't need it.
To DRM Monoballs, LG Drop Spindles and Baer bumpsteer kit...
Quick Reply: DRM Monoballs, LG Drop Spindles and Baer bumpsteer kit...
