EBC "Yellowstuff" brake pads. Used 'em lately?
Old 11-20-2013, 11:59 PM
FruiTay
FruiTay's Avatar
Default EBC "Yellowstuff" brake pads. Used 'em lately?
The reviews I found were years old. Looks like a decent pad for some street and light track use. Have any experience with them?
Old 11-21-2013, 12:59 AM
Saucee
Saucee's Avatar
I'm running them now, honestly they're a great pad. Make absolutely no noise on the street, dust isn't bad and they work well on the track.
Old 11-21-2013, 03:35 PM
FruiTay
FruiTay's Avatar
Great! Got me a set coming. I'm gonna try 'em out on the 30th.
Old 11-21-2013, 11:40 PM
hungryhippo
hungryhippo's Avatar
I use them on my 4000+ lb daily driver. I'm very happy them and even tested them at laguna seca twice.
Old 11-23-2013, 09:29 PM
Gray Ghost GS
"AlohaC5" Senior Member
Support Corvetteforum!
Gray Ghost GS's Avatar
I use the EBC Yellows for when I'm daily driving - great upgrade from OEM and would do very well for HPDE 1 and 2, but I don't think they would take the abuse very well on the road courses for more advanced drivers; depending on how aggressive your braking is around the track and other factors.
Old 11-24-2013, 10:21 AM
Hi Volts Z06
Hi Volts Z06's Avatar
I used them for one track day back in 2010 at Pocono running double infield. I got about 20 laps on them with bad fade and at the end of that session I had about a quarter of a pad left. Use them for the street but FORGET about taking them to the track.
Old 11-24-2013, 12:34 PM
FruiTay
FruiTay's Avatar
Do you consider yourself "advanced?" What brake setup do you have?
Old 11-24-2013, 08:34 PM
Hi Volts Z06
Yes...I am a licensed race driver and instructor. Back then I had stock C5 Z06 brakes on the car. I upgraded to a StopTech BBK in the front that season and then realized the rear brakes are as woefully inadequate. I added the rear StopTechs the following season and between those and my Carbotech pads, I don't have any issue with brakes anymore.
Old 11-24-2013, 09:45 PM
FruiTay
FruiTay's Avatar
oooh thank you for your input. You have been the only negative reviewer so far. You're much better of a driver than I so hopefully they will be ok for me, for now. I was going to do the Carbotech XP12/10 but these were on Amazon with quick shipping so I could get them here and installed before my next track day on the 30th.
I have SS caliper pistons and lines with a Quantom brake duct kit so hopefully that will help a bit. I appreciate this and any other input you can provide!
I'm planning on the AP T1 sprint kit for my brakes when I can afford it. Keeping the stock wheels seems like a plus.
Old 11-25-2013, 01:00 AM
hungryhippo
For light track use while being aware of the limitations, they're fine. If you will be driving hard then they won't do too well, they're still a street pad.
To EBC "Yellowstuff" brake pads. Used 'em lately?
Quick Reply: EBC "Yellowstuff" brake pads. Used 'em lately?
