Suspension model
Old 11-24-2013, 06:17 PM
383's Avatar
Default Suspension model
Has anyone done a stock suspension model like the one in this link
http://farnorthracing.com/autocross_secrets16.html
I'm not sure what everything means and teaching yourself is somewhat difficult
Old 11-24-2013, 10:04 PM
eogel
eogel's Avatar
Search for Brian Cunningham threads. Some time ago he was doing some work in this area, but it was targeted at the C4. Not sure how deeply he went into it.
Old 11-26-2013, 05:50 AM
DG-FNR
2nd Gear
DG-FNR's Avatar
I have, somewhere, a suspension model for C5.
As you would probably suspect.
What do you want to know?
DG
Old 11-26-2013, 03:15 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
I have a Solidworks model for the C4
haven't put it into an analysis program
Old 11-26-2013, 08:05 PM
383's Avatar
Just trying to figure out the perfect spring rates/frequency for *****-n-giggles. Im not keeping this car for much longer but I thought Id try to understand these things before setting up my C6Z
Old 11-26-2013, 08:55 PM
383's Avatar
DG
I just did some reading, you're kind of a big deal in auto-x!
Prepare for numerous dumb questions about setup!
Old 11-27-2013, 10:41 PM
383's Avatar
DG
Can you figure out CG from a model and actual measured ride height? I must need corner weights for this correct?
What angle do I want my control arms at for optimal camber gain/ride height
Old 11-29-2013, 07:51 AM
geerookie
geerookie's Avatar
Here's how I do it.
http://www.longacreracing.com/articles/art.asp?ARTID=22
Old 11-29-2013, 10:02 AM
jtmck
jtmck's Avatar
Originally Posted by geerookie
If you only raise the car 10", you will get a 30# to 50#number change. Not enough when a 5# change will equal 1.5" difference in CG height.
You will have to raise the end of the car 30" to get a worthwhile reading.
Yes, it is scary....
Old 11-29-2013, 06:12 PM
383's Avatar
Awesome thanks for the link!
What do you guys use for locking the shocks in place?
Old 12-06-2013, 02:25 PM
geerookie
geerookie's Avatar
Depending on the total weight of the car F/R bias and wheel base that MAY be true.
Where are you coming up with a 1.5" CG height change as a result of a 5lb diff.? What's the math?
Old 12-06-2013, 02:46 PM
383's Avatar
What do you guys use to keep the suspension from moving while lifting?
Old 12-06-2013, 04:56 PM
jtmck
jtmck's Avatar
Using your calculation formula....
Insert car numbers, including the 10" raised height, then change the loaded number by 5#, result difference is how much?
This is why I had to use 30" height.
Jim M.
Old 12-06-2013, 08:38 PM
TLGunman
TLGunman's Avatar
I'm surprised Morse Measurments doesn't have a Vette in their catalog of K&C data:
http://www.morsemeasurements.com/pro...-car-database/
Old 12-08-2013, 09:40 PM
383's Avatar
Are you guys doing this without locking the suspension from moving?
Old 12-09-2013, 11:13 AM
jtmck
jtmck's Avatar
You remove the shocks and springs. Replace the shocks with a solid link, adjustable to ride height.
Old 12-09-2013, 09:33 PM
383's Avatar
Where would one go about finding one of these, or 4?
To Suspension model
Quick Reply: Suspension model
