FS: C4 ABS front hubs w/extra ring
Old 12-27-2013, 11:25 AM
indianavette
indianavette's Avatar
Default FS: C4 ABS front hubs w/extra ring
Wheel spacers and different offsets on Tommy Morrison's early '90s ZR-1 race cars altered the alignment of ABS sensors with the cogged ring on the hubs. His solution was to weld an extra ring to the backside of the hub, which returned the alignment to spec. Here's what it looks like. If you're running a wider track and it's affecting your ABS, you might consider a set of these. I have several like-new spares from the race program. They're in mint condition. Studs are stock. Asking $200 apiece.
Old 12-27-2013, 12:57 PM
Rob31
Rob31's Avatar
Are you saying those guys spaced the hub out that far ? Any more info on this ?
Old 12-28-2013, 04:21 AM
Crepitus
Crepitus's Avatar
Ya what he^ said
To FS: C4 ABS front hubs w/extra ring
Quick Reply: FS: C4 ABS front hubs w/extra ring
