AutoX -315F/335R wheel size
Old 01-06-2014, 10:58 PM
rocket71
rocket71's Avatar
Default AutoX -315F/335R wheel size
I was hoping to get some feedback on proper wheel size. I bought my SSP Vette ready to go. It is a 9/10 prepped car. I am going to leave it untouched as I start the campaign next year. I do need a new set of wheels though. Presently the car has been running on 315/30/18 front and 335/30/18 year A6s. I like the balance of the car with that tire size. I am currently on 18x10.5 CCW's. What is the recommended wheel size that rubber I am running? Anyone with experience on a wide wheel for that rubber and autox? From looking at how pinched the tire is I would think something wider would put more contact patch down if something wider will fit.
Thanks!
Old 01-07-2014, 01:31 AM
steponc
Support Corvetteforum!
steponc's Avatar
St. Jude Donor '14
10 or 11s in the front
12 or 13s in the rear. these will require a mini tub
Old 01-07-2014, 07:39 AM
rocket71
rocket71's Avatar
So at 10.5, I am good in the front. I can't tube the rear, class rules won't allow it.
Old 01-07-2014, 08:10 AM
Hi Volts Z06
Hi Volts Z06's Avatar
Call John at CCW- My 12" rears fit with 335's, no spacers, no tubs. There's about 1/4" of clearance. You probably will see a bit of rubbing in the wheel well (nearest to the frame) but not enough to damage the tire. (Just enough for a little scuffing under hard cornering). You can always run a 1/4" spacer if that's objectionable.
Old 01-07-2014, 08:52 AM
JiminVirginia
JiminVirginia's Avatar
Agree. I ran that tire setup for three years on CCWs, 18x11 inch fronts and 18x12 inch rears. 315 fronts and 335 rears A6s.
I used a 1/4 inch spacer on the rears. No tub needed. You will just barely clear the air duct.
Jim
Old 01-07-2014, 07:04 PM
theseal
theseal's Avatar
Thanks!
c5 or c6?
My c6 felt best with 12's front with 335's and 13's rear with 345's, though i never tested back to back with smaller tires.
i have now decided that buying hoosiers for solo is just not a fruitful use of my budget though...
Old 01-08-2014, 07:58 AM
rocket71
rocket71's Avatar
C5, this car is only used for Solo.
To AutoX -315F/335R wheel size
Quick Reply: AutoX -315F/335R wheel size
