Continental fronts C6Z, What is the correct size
Old 01-09-2014, 02:23 PM
rabrooks
rabrooks's Avatar
Default Continental fronts C6Z, What is the correct size
The continental tires have strange size reference numbers. Can some one tell me what is the closest Conti track tire to the factory C6Z fronts
I have 305 xxxxx on there now but they are too wide for the wheel and the diameter is a little larger. Their useful life is gone so I want to get another pair but I'm not sure what to order
Roger
Old 01-09-2014, 05:01 PM
GT Racing Tires
Supporting Vendor
GT Racing Tires's Avatar
Depending on your front wheel size and rear tire size. You an run a 285/645/18 or 305/650/18. For actual height divide the middle number by 25.4, 645=25.39.
Old 01-10-2014, 12:14 AM
blkbrd69
blkbrd69's Avatar
For stock front wheels this is what I used.
And Todd should have a new batch in.
Old 01-10-2014, 01:18 PM
rabrooks
rabrooks's Avatar
Thanks for the responses. I have a set of 305"s on the front now. They are a little too wide. Height is ok but a taste on the tall side. They were rears on a c5 base car. I used them because they were available at the track when I corded my other ones. I didn't save the corded ones to get the size from them
Cheers
Old 01-10-2014, 01:22 PM
rabrooks
rabrooks's Avatar
What is the width of these two tires?
Old 01-10-2014, 02:03 PM
blkbrd69
blkbrd69's Avatar
285 and 305
Old 01-10-2014, 03:47 PM
rabrooks
rabrooks's Avatar
ok so that's mm. 305/25.4=12. So that's definitely too wide for the front. I just looked at my tires. They are 305 660 18. that's 25.98 tall. That height will work but its a little too close. The width is a good bit too wide.
Thanks for the help guys
Old 01-11-2014, 12:49 AM
blkbrd69
blkbrd69's Avatar
I am actually running the 305's on C5Z rear wheels on the front of my C6Z now.
The car pushes less with more tire up front, but no the 305's didn't fit the stock wheel to my preference, but others are running them just fine.
However the 305 will not work with active handling on, the dia. is to far off.
To Continental fronts C6Z, What is the correct size
Quick Reply: Continental fronts C6Z, What is the correct size
