Need GoPro Track Video to display Fractions of s asecond
Old 01-28-2014, 11:58 AM
urslooow
urslooow's Avatar
Default Need GoPro Track Video to display Fractions of s asecond
Started using the Hero3 black on 1080-30 narrow and got it transferred to computer but windows video and quick time do not display fractions of a second. is there a way to do it or turn it on? thx
Old 01-28-2014, 12:21 PM
Scooter70
Scooter70's Avatar
Are you trying to figure out laptimes? I had the same issue and ended up installing GoPro's editing software.
http://gopro.com/software-app/gopro-...-edit-software
Old 01-28-2014, 12:37 PM
froggy47
froggy47's Avatar
To my knowledge gp hero3 does not have a timer built into it. Are you trying to lay timing on top of gph3 video somehow?
Old 01-28-2014, 12:39 PM
urslooow
urslooow's Avatar
yes trying to get lap times. I don't care about laying the time on the actual video I just wanna get lap times to the 1/100th of a second during play back ths
Old 01-28-2014, 01:25 PM
RDnomorecobra
RDnomorecobra's Avatar
i know the preview panel in Windows movie maker has fractions. you could try importing it into that and playing it back
Old 01-28-2014, 02:47 PM
rbl
rbl's Avatar
Not going to happen. I doubt the frame rates will give you that accuracy, much less watching it as a video.
Old 01-28-2014, 02:57 PM
FuriousDonuts
FuriousDonuts's Avatar
Getting it down to 1/100th of a second will be impossible since the video was recorded at 30 frames per second, which means each frame advances every .033 seconds. That also means at 100mph, you're traveling ~5 ft between every frame. Both of these factors make it tough to pin down exactly when you cross the start/finish.
Assuming you're ok with those parameters, you can get a pretty close estimate. +1 on using a video editor. You can cut the video on the nearest frame when you cross the start & finish, and if it doesn't give you the fraction, just count the number of frames after the last whole second and multiply by 0.03333...
Old 01-28-2014, 03:11 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
30 fps so you only have 30 samples per 1 sec. close enough for ballpark timing
Old 01-28-2014, 04:43 PM
lefrog
lefrog's Avatar
This is going to be better than any GPS timer anyway since they run at 10Hz. You would have to run a GoPro black at 120fps to get down to the 1/100th accuracy.
Any decent video editing software will count frames. Even the free Windows Live Movie Maker that comes with Windows will give you that accuracy (that is 3.33/100th at 30fps).
Old 01-30-2014, 10:38 AM
urslooow
urslooow's Avatar
do u guys use the roll bar moune or the windshield?
Old 01-30-2014, 03:35 PM
lefrog
lefrog's Avatar
If you have a rollbar, use the rollbar mount.
If you don't, you can still attach it to the passenger bar on the dashboard if you have one of these flex straps.
Old 01-31-2014, 08:01 AM
Scooter70
Scooter70's Avatar
It depends on what you want to see. I like to see the track so I put a sticky mount behind the rearview mirror. The only issue that I have with it is that it rattles a little bit so there's some extra in the audio. I'm fixing that this year with an external mic that I will run out the back near the exhaust tips. If you want to see more of the driver, I'd go for a rollbar mount.
Old 01-31-2014, 07:54 PM
JDIllon
JDIllon's Avatar
Steve, I mount the camera on the windshield to get a better view of the track. I don't have the GoPro 3, I have the Hero 2 so when I have mounted it on the roll bar, the view is to much of a wide angle for what I want. Try both and see which one you like better. Hope to see you at an event in the near future?? JD
To Need GoPro Track Video to display Fractions of s asecond
Quick Reply: Need GoPro Track Video to display Fractions of s asecond
