Wet Sump Reliability
Old 02-09-2014, 11:50 AM
Trention
Trention's Avatar
Default Wet Sump Reliability
I'm new to vettes and I anticipate taking my base 2011 to the track on occasion (Putnam Park if there are any other Indiana regulars) but I'm wondering if the wet sump arrangement has a history of problems under track use.
Thanks in advance
DaveT
Old 02-09-2014, 04:29 PM
Dirk Miller
Dirk Miller's Avatar
Default Canton type Accusump?
Thanks in advance
DaveT
If your thinking about an Accusump, you don't want to ask me about my ongoing experience
Old 02-09-2014, 06:16 PM
ErnieN85
ErnieN85's Avatar
Thanks in advance
DaveT
If you stick with street tires at Putnam, you won't have a problem. problems show up on slicks when you get higer G loads for longer times usually in left hand sweepers
Old 02-09-2014, 07:25 PM
Painrace
Support Corvetteforum!
Painrace's Avatar
For the street, wet sump fine. For track use you need an ARE dry sump system. go to www.drysump.com. Call Gary.
Jim
Old 02-10-2014, 10:50 PM
Petrolburner
Petrolburner's Avatar
Only a problem on race rubber from what I've read. You can even run DOT R-comps without losing oil pressure. Full on race slicks with a talented driver running hard is where the oiling issues appear. Nothing to worry about on street tires, except overheating the brakes.
To Wet Sump Reliability
Quick Reply: Wet Sump Reliability
