Grr.. how does one remove the OEM bushings from the A-arm pin?
Old 02-21-2014, 03:52 PM
Armycop
Armycop's Avatar
Default Grr.. how does one remove the OEM bushings from the A-arm pin?
Swapping out my stock A-arm bushings with a Pfadt set, but I can't get the OEM bushing off the pin! Clamped it in a vise (didn't work) and then cut one through to the pin, but it seems to be glued on there! I'm hesitant to apply a torch to the pin/bushing; is there another way that I'm missing?
Old 02-21-2014, 04:21 PM
ErnieN85
ErnieN85's Avatar
I used a shop press, most use either a vise, a bolt and a large socket or burn them out
Old 02-21-2014, 04:22 PM
Armycop
Armycop's Avatar
Sonofa...at least one of them was melted/glued onto the a-arm pin! Rubber bushing everywhere now...not looking forward to cleaning these up.
Old 02-21-2014, 05:15 PM
Armycop
Armycop's Avatar
Getting them out of the a-arm was easy, they pushed right out. Getting the rubber off the a-arm pins is another story entirely.
Old 02-21-2014, 05:18 PM
giantkeeper
giantkeeper's Avatar
Heat gun and a bench vise will handle all of the bushings with ease. You just need to cut one side of the bushing off, heat and twist/pull and they pop right out. Uppers, lowers, front/back.
Just re-read, you need to save the pins. I did VB&P so didn't have to save that piece…….disregard.
Old 02-21-2014, 05:26 PM
JDIllon
JDIllon's Avatar
Am I missing something? New pins are supplied with the new bushings. This system works well. I could not find the one that uses the threaded rod and washers, it works the best and is the easiest. JD
http://forums.corvetteforum.com/auto...-pictures.html
Old 02-21-2014, 05:52 PM
froggy47
froggy47's Avatar
What he said, the ones I got for my c5z (a few years ago) included new pins. WTF?
Are they selling a revised kit that reuses the stock pins?
One of the unique features of the pins I got was they are 180deg rotateable for 2 different camber settings. It would be a shame if it's no longer that way.
Old 02-21-2014, 09:00 PM
sperkins
sperkins's Avatar
Something's not right. Press the stock bushings out and find the nearest trash can. The Pfadt bushing kit comes with the pins needed for their bushings.
I have 2 spare sets if anyone needs them.
Old 02-22-2014, 05:18 AM
Armycop
Armycop's Avatar
hm. Okay, I need to dig into the box again and see if the pins are in there. Standing by..
Old 02-22-2014, 02:32 PM
froggy47
froggy47's Avatar
Find the directions & go thru them. It is a fairly specific install you should follow, otherwise you may not be happy with the result.
Old 02-22-2014, 05:49 PM
Armycop
Armycop's Avatar
Yup its official, I'm an idiot. The new pins were in one of three bags. Now to business!
Old 02-22-2014, 05:57 PM
Scooter70
Scooter70's Avatar
We'll remember that.
Old 02-22-2014, 08:16 PM
Armycop
Armycop's Avatar
Hell, you've seen in person the levels of stupidity I can achieve!
Old 02-22-2014, 08:44 PM
ErnieN85
ErnieN85's Avatar
Gues that make you human
To Grr.. how does one remove the OEM bushings from the A-arm pin?
Quick Reply: Grr.. how does one remove the OEM bushings from the A-arm pin?
