Doing pfadt swaybars and shocks, what else should I consider replacing?
Old 02-22-2014, 06:19 AM
Chris Edwards
Chris Edwards's Avatar
Default Doing pfadt swaybars and shocks, what else should I consider replacing?
Curious if there is anything else in the suspension that might need replacing while I'm in there. Car is an 01 z06 with 67k
Old 02-22-2014, 06:42 AM
John B
Pro Mechanic
John B's Avatar
Mushy bushings
Old 02-22-2014, 09:49 AM
crimlwC6
crimlwC6's Avatar
Yep. I assume it is a street car so you'd likely want polys instead of monoball. I'd also get a camlock kit.
Old 02-22-2014, 12:44 PM
Chris Edwards
It's a daily driver / hpde car so I'd like to stay away from poly bushings... What's a camlock kit?
What about the DRM rack bushing?
Old 02-22-2014, 01:44 PM
crimlwC6
crimlwC6's Avatar
http://hardbarusa.com/hardbar/produc...products_id=56
I don't know anyone that has run the steering rack bushings but I don't think DRM sells any fluff. I've talked to Doug and he is a solid guy. I know pfadt used to sell a camber kit because I have one but I couldn't find it on their website.
Old 02-22-2014, 10:27 PM
db2xpert
db2xpert's Avatar
Pfadt discontinued the camber kit.
Old 02-22-2014, 11:30 PM
froggy47
froggy47's Avatar
You need to read the other thread about Pfadt, not good news.
Search.
To Doing pfadt swaybars and shocks, what else should I consider replacing?
Quick Reply: Doing pfadt swaybars and shocks, what else should I consider replacing?
