C6 harnesses with stock seat
That being said, without a good seat it only helps a little. And most would argue you shouldn't do just a piece of the safety solution: Seat/harness/HANS. They should all be done at once.
PCA and BMW events, and maybe SCCA nowadays, generally require that a seat must be manufactured with the pass-through holes in it. Modifying a stock seat may not be acceptable. Many track day groups follow PCA, so just check when you register for a track day to make sure you'll meet their tech requirements.
There are several threads about this - take a look at these:
http://forums.corvetteforum.com/c6-c...t-harness.html
http://forums.corvetteforum.com/c6-z...e-schroth.html
As mentioned in the previous post, a harness is just a part of the overall restraint system. Once you begin modifying the restraints you start down a slippery slope that really requires seat, harness, HANS, and a padded rollbar/cage.
Also, if you will have somebody riding in the passenger seat (instructor/coach/passenger) most organizations have an "equal restraint" rule that requires both seats to have similar restraint systems - if you put a harness in for the driver, there must be one for the other seat as well.
Just FYI!!
Bob
Have you looked at Angel Pads as an alternative to a harness? They're a great option if you want to stay with the stock seat, especially if you use your car for more than just autocrossing.
I have a stock 05/06 Seat that has the harness pass throughs in it I got from another member here if you would be interested. I'm never going to use it...
Received 8,927 Likes
Have you tried to use seat belt cinch mode? Using cinch mode you can get the lap and shoulder belt tight enough to plant your butt down in the seat and keep your upper body from moving forward/backward. The upper body will still slide side to side and your knees will move back and forth in the opposite direction but your butt will not slide around. Just run the seat all the way back, get in the car, pull the belt all the way out until it stops and then let it ratchet back in to the take up reel as you latch it. Then pull the belt as tight as possible while feeding the slack into the take up reel. Once you get tight as possible then move the seat forwrd to your driving position. If the belt is fastened properly the lap belt will feel like it cutting you in half and the shoulder belt will be tight across your chest and limiting your breathing.
Bill
Bill
Bill
Bill
I may just live with the chich mode until I decide to move to time attack/track days and go full cage, seat, etc.
I have gone thru the stock seats, I hated to lose the side air bags and use a Hans device and harness bar. also have come thru the seat bottom for the 5 point, the system works pretty well to hold me in the seat, bought the collars from safer racer $15. I run multiple PCA groups have never had an issue. I suppose if they wanted to they could make me use the 3 pt belts that are still in the car for everyday use. I had a roll bar set up on my o8 c6 and felt a little safer.
Bill
I forget where i got them but somewhere i was able to buy a mounting bracket that was made for the c6 and c6z seats that just fit . you just need to be careful cutting seat for sub not to cut seat heater, springs not an issue.
Feeling safer could be good
Got suggestions of sources for a C6 roll bar?
How did yours fit? (getting off from the original subject here but my wife would appreciate your response)
If you don't want to modify or replace the seat, you can get what are called "dick straps". I didn't name them. they go around your headrest, and are made of seatbelt webbing materials and have two loops, one on each side, that the harness shoulder belt goes through. They keep the shoulder belt up above your shoulder where they need to be. Used to have a set for both seats, but gave them to a buddy when I went to a racing seat. Still need a harness bar though. Jerry
