Pad changing on C6 Z06 calipers
How big of a pita is changing the pads (6 front / 4 rear)for track use on the C6 Z06 calipers? I'm considering converting Z51 brake setup to Z06. Can you change them by top loading, or do you have to swing the caliper open.
The easiest way is to remove the caliper, I use an electric impact wrench. you can just take the padlets out by pulling the pins but they (pins) often get stuck then you have to take the caliper off any how.
Supporting Vendor
St. Jude Donor '11,'13
but, you still need to remove the bottom 2 caliper bolts. No messing with pins though
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
