C5 motor mounts
Old 03-04-2014, 11:40 AM
Z06VENOM
Z06VENOM's Avatar
Default C5 motor mounts
It's basically a track car now, I doubt it will see much street this year...
Texas speed long tubes, no cats, cammed, 435 RWHP.
I am concerned about melting and knock sensor issues... What is everyone using these days?
Old 03-05-2014, 12:55 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
I put the Hinson ones in mine when I had the oil pan off. I don't think they are as hard as the Pfadt ones were. Couldn't tell that big a difference with new, but stock ones were about gone anyway.
Old 03-06-2014, 09:53 AM
Z06VENOM
Z06VENOM's Avatar
I sent off an email to Hindson, thanks!
I was going to make solids but, read somewhere that the knock sensors may pick up false knock if the mounts are too stiff.. Hopefully these won't be a problem
You are running long tubes? Do you run a shield to protect them from heat?
Old 03-06-2014, 10:08 AM
breecher_7
breecher_7's Avatar
Hinson is the way to go. Use the heat shields from your factory mounts. If you dont have them, just wrap them in heat tape.
Old 03-07-2014, 03:40 PM
Apocolipse
Apocolipse's Avatar
Received 1,281 Likes on 926 Posts
I make my own aluminum solid ones.
Works great.
Old 03-07-2014, 04:19 PM
ScaryFast
ScaryFast's Avatar
Works great.
You wouldn't happen to have your mount height dimension handy, would you? I am about to make some from aluminum roundstock. I assume you replace the hydraulic portion and keep the factory aluminum brackets which bolt to the block, right?
Old 03-07-2014, 05:10 PM
MySR71
MySR71's Avatar
Has anyone tried the engine mounts from MTI Racing?
http://www.mtiracing.com/c5-c6-alumi...id-mounts.html
Old 03-07-2014, 05:39 PM
RX-Ben
RX-Ben's Avatar
If you go solid, you might render your knock sensors useless. At least that is what I have heard.
I have a set of delrin mounts, which is a pretty ideal material. Knock sensors still work, but the mounts are no longer available (from a small Canadian shop, I think).
Old 03-07-2014, 07:39 PM
Apocolipse
Apocolipse's Avatar
Yes I keep brackets on the engine. I'll measure it for you when I get back home, not sure on the knock sensors, I have a feeling some do some don't.
You can also lower the engine about 1/3" as well like some other offerings for dropped mounts without worrying about hitting anything
Old 03-07-2014, 08:18 PM
ScaryFast
ScaryFast's Avatar
They look nice but that's a lot of design for something that can be replaced by a round metal puck with a hole drilled through it. Have you seen Greg's on the blue car? That's what I plan to replicate with about $4 worth of aluminum and a drill press.
Although doing the same thing with delrin seems like a good idea, too. Shouldn't be too hard to find a round bar of it.
Old 03-07-2014, 08:21 PM
ScaryFast
ScaryFast's Avatar
And BOOM goes the dynamite. 1 ft of 3" delrin round stock is $252!
Think I like aluminum again...
http://www.grainger.com/product/DELR...6vp?s_pp=false
Old 03-07-2014, 10:42 PM
passons
passons's Avatar
Hinson should be OK.
Old 03-08-2014, 12:24 AM
mgarfias
mgarfias's Avatar
Damn. Same thing is $60 at mcmaster.
Old 03-08-2014, 04:49 AM
MySR71
MySR71's Avatar
No, I haven't. Looks like there are plenty of ideas floating around though.
Old 03-09-2014, 03:07 AM
derekdj87
derekdj87's Avatar
Would lower engine mounts make any noticeable difference with lower center of gravity? The MTI one knocked off 1/2in, that seems like a good bit.
Old 03-09-2014, 02:47 PM
froggy47
froggy47's Avatar
The min/max temps on that delrin don't seem very impressive. 30f-180f?
Old 03-09-2014, 03:14 PM
giantkeeper
giantkeeper's Avatar
If you are shopping materials for mounts, US Plastics is pretty good. I use them for odds and ends.
In the BMW community people have started using UHMW. Doubt that's really new, but it's another idea.
Acetron/delrin
UHMW
To C5 motor mounts
Quick Reply: C5 motor mounts
