New tranny cooler idea
I've been testing this setup for about 9 months now through 4 HPDEs at Sebring and Homestead. I used to get the transmission fluid overheating warning by the 3rd session, and could only run about 10 minutes on the 4th session of the day. Ambient temp didn't matter, January at Homestead (in the low 80s) was no better than June at Sebring (mid-90s).
With this setup, I did three straight sessions (60-70 minutes straight) at Sebring in December (mid-80s) with no issue, and ran all day at Homestead.
It's an air to oil cooler (Setrab plate design). It uses the space where the leaf spring used to be, along with a bottom scoop to pull air through it.
My car is an 07 Z06, so it's got built-in pumps and the fluid-fluid heat transfer setup for the differential fluid.
Monitoring the temp (using a DashLogic) shows track temps around 245 at the end of a session, and street temps around 195 (with highway temps or stop and go traffic not mattering all that much).
Here's a few pics:
Here's a few pics:
No, I don't think so. Or at least to keep the existing ground clearance, anyway.
I'm using the stock heat transfer cooler from the diff, so I'm keeping the tranny fluid cool, which keeps the diff fluid cool.
It would be nice to have some actual data on the differential temps though.
awesome.. I'm doing the same idea of a cooler different place though.. I was worried if the trans pump had enough oomfff to flow the fluid.. I guess there is no issue huh?!!!
Received 8,919 Likes
Wonder how much a larger radiator would have helped in cooling the transmission fluid? I haven't had issues with my C6Z but I did burn up a diff in my 97 due to overheating it at a track day. No whine before lots of whine after.
Bill
Bill
This method solved that.
Nice design! That is a nice clean way to add a trans cooler. Did it lower your engine coolant temps any? Seems like it may help slightly with coolant too since you eliminate the hot fluid from the radiator tank.
I'm wondering if I can use the old tranny cooler in the radiator for the power steering fluid, and get rid of the OEM "skin remover".
I've got a future project in mind to upgrade the front rack and PS pump to a TurnOne setup, and maybe I'll look into that. I'll need to add a sensor to test before and after temps though.
