How Chevy keeps the tire from rotating on the rim
Try this. Thanks Brian!
http://www.autoblog.com/2014/03/13/c...m-fixed-video/
They media blast the rib BEAD for better grip, wonder if they get slow leaks?
I think the problem was in the original GM blog posting.
Former Vendor
The main cause of slippage is when the wheel is over-cut on the lathe, removing excess material from the bead seat and reducing the OD of the bead seat. When you combine a wheel that is over-cut and a tire that is on the big end of the spec, it will move.
You're talking about slipping wheels, I'm talking about flying cars. I really do like your logic though, I hadn't thought of it that way. I don't think it's the engineers so much as the marketing team reaching out to people who've never encountered this phenomenon and GM trying to overemphasize how sticky their factory supplied rubber is. Think of it as the existence of Z/28s selling V6 base cars.
Hmm, those look absolutely identical to some wheels a friend just purchased.
On another note, flying car mode!
"Flying Car": Performance Traction Management -- 2014 Camaro Z/28 | Chevrolet - YouTube
I used Permatex High Tack in the can with the brush on my drag car, brush it on the bead dry and mount the tire.
Comes off just fine and it wont rotate.
