Carbotech pad compound to Hawk equivalent
Old 03-14-2014, 09:59 PM
stevensa
stevensa's Avatar
Default Carbotech pad compound to Hawk equivalent
Hi all,
When comparing similar pads, what is the Hawk equivalent of an XP12 and XP10 compound?
Old 03-14-2014, 10:23 PM
Scooter70
Scooter70's Avatar
Probably DTC60s. I would also recommend that you check out Raybestos ST43. After using the DTC60s for years I tried the ST43s last year and was very impressed with them. Same feel, similar torque, and better life for rotors and the pads themselves.
Old 03-17-2014, 10:05 PM
stevensa
stevensa's Avatar
I have considered those as well, seems like lots of people are happy with them.
Does DTC70 = XP12 and DTC60 = XP10 sound right?
Old 03-17-2014, 10:46 PM
Supercharged111
Supercharged111's Avatar
Having used all 3, I'll say the Hawks are KILLER on the rotors. They suck cold too, but feel great when warm and seemed impossible to overheat. The Rays were much easier on the rotors, but I haven't run them on the Camaro yet. On the Vette I ran XP10 and ST43 and the ST43 was hands down the better track pad. The XP10 goes a little soft when warm and the ST43 didn't.
Old 03-18-2014, 01:22 PM
kimmer
kimmer's Avatar
C4 of the Year Finalist
Always ran Hawk but just installed the carbotech so I will soon find out.
Old 03-18-2014, 01:46 PM
Hat_Trick_Hokie
Hat_Trick_Hokie's Avatar
I believe that is the correct conversion
I use that DTC70/DTC60 split with good results on an otherwise stock C5 coupe.
To Carbotech pad compound to Hawk equivalent
Quick Reply: Carbotech pad compound to Hawk equivalent
