Wilwood Carbon brakes for C5/C6
AERO6 WCCB Carbon-Ceramic Big Brake Front Brake Kit
AERO6 WCCD Carbon-Ceramic Rotor Front Brake Kits offer an extreme performance upgrade featuring WCCB Carbon-Ceramic Dynamic Mount Rotors with Wilwood’s exclusive Bobbin Mounting System. AERO6 WCCD kits are engineered to maximize braking capacity inside custom wheels. These brake kits offer a simple bolt-on installation with minor modifications required to the front spindle only and are fully compatible with ABS and OE master cylinder output. W6AR calipers are a competition proven and offer fully detail machined forged caliper body demonstrates superior strength and resistance to deflection and separation under high load. A high temperature, fluid resistant “Quick-Silver“ Nickel plate is the standard for performance, other colors (Black and Red powder coat) are available as options. 14.00” WCCB rotors are made from a proprietary blend ceramic matrix composite material commonly known as Carbon-Ceramic and dynamically using Wilwood’s proprietary integrated anti-rattle Bobbin Mounting System. WCCD rotors offer higher thermal conductivity and heat capacity in excess of conventional iron or titanium rotors of similar or even greater weight and have been developed to withstand extreme temperatures with the highest possible degree of resistance against distortion, warping, cracking and wear.
Front:
http://www.wilwood.com/BrakeKits/Bra...tte&option=C-6
Rear:
The calipers:
http://www.wilwood.com/Calipers/Cali...no=120-13290-N
The new Aero6 forged six piston caliper delivers heavy duty stopping power for the road or track. The caliper incorporates race technology into a body design with widespread adaptability. Radial mounting, multiple options for piston volume, and a rotor diameter ranging from 12.19" to 15.00" give this caliper the versatility necessary to suit all types of heavy weight braking requirements. The new Aero4 is the latest innovation to the W4A / W6A series of calipers. It has been redesigned with internal fluid ports that eliminate the external fluid cross-over tubes and massive center bridge assembly.
The body of Aero series is stress-flow forged from a premium grade aluminum alloy billet. Stress-flow forging realigns the metal's internal grain structure to flow within the contour of the caliper body. This process eliminates the stresses and interruptions to the internal grain structure that occur when machining a straight block billet. The results are a caliper with superior clamping efficiency and ultimate strength against fatigue, stresses, and distortion under load.
Considering the discounts your company offers, is it safe to assume that carbon setup would go for roughly 10k?
Former Vendor
I'd have to pull up the numbers for you. But as you suspect: you call; you call you save.
Received 8,928 Likes
Todd, will those rotors fit in my front W6As that run with the stock 14 inch Z06 rotor?
While I was looking at Wilwood's web site I noticed there is a new Bobbin Style rotor hat that may better than the hats I have now. Can the rotor rings that I have now interface with the newer hat or do I need special rotors?
Bill
Bill
Former Vendor
Bill
Bill
Let me do some research on it Bill.
Former Vendor
Bill
Bill
So...how are these compared to the Z07/ZR1 Brembo units?
I just drove a Lambo Guillardo and a Ferrari 458 last weekend at CotA. The Brembo units were awesome! And so consistent lap after lap after lap! I was waiting to brake until the 150' - 170' mark into T12 doing about 155-160 mph and it was stopping well short of the corner.
Just curious...I'm looking to use carbon-ceramics for the C4 track car. If I can get the ZR1/Z07's for $8k complete, and these are $12k (retail)...they better be light years better.
The oem brembos have dust boots which can melt off.
You can get the wilwoods with with titanium piston inserts.
The wilwood rotors are solid faced, instead of drilled.
Wilwood offers the option of a zinc finish or powdercoated instead of only powdercoat with the brembos
Former Vendor
I'm digging for more info on time etc. when I have some more that's worth sharing I will.
That being said, the $8k price point won't be broached I'm certain. Better...? That's going to be a bit subjective I suppose. The optional nickel plate and thermlock pistons are nice but even at the good buddy price point you'll still be in the $10K plus range.
