Throttle Blip Controller - Pivot 3-Drive BLP
Old 03-26-2014, 02:47 PM
cyber-vette
cyber-vette's Avatar
Default Throttle Blip Controller - Pivot 3-Drive BLP
It’s not the same rev matching as the C7 but may be the best alternative. I ordered one and will have it next month. I looked at ordering the Auto Blip. Hopefully I will have Pivot 3-Drive BLP working and repost next month when I get it. Until then if you all would read up and let me know what you think til then. Price is $280 shipped It looks very cool.
Throttle Controller Auto-Blipping
Pivot 3-Drive BLP
User manual
User Manual
Place I purchased it from - Japan
Nengun
Old 03-27-2014, 09:26 AM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Let us know how it works.
Old 04-25-2014, 08:26 PM
cyber-vette
Well I purchased the Pivot BLP and as soon as it was connected to the APSA and APSB wires it caused a fault code with the Active Handling and Traction Systems. If failed but not for lack of trying.
Old 04-27-2014, 11:39 AM
moose.b3
moose.b3's Avatar
Curious as to why you didn't order the Auto-Blip? In past threads it seemed to work pretty good.
Old 04-27-2014, 02:08 PM
cyber-vette
I tried something that electronically was better IMO. Controlling both Throttle control and Throttle Blip ability. The Pivot device works on many Import cars but failed to work with the Corvette BCM. I sold it to a friend who has a Nissan 350Z which it works quiet well on.
My next project is the Auto-Blip with LGM shifter **** aka "Man ****". Instead of the clutch pedal switch controlling the throttle blip I am going to adapt the LGM **** with a Momentary switch and 30 amp relay to allow throttle blip when the button is pushed. This will allow me to control when the throttle blip is done. I should have it installed and running next month.
Old 04-27-2014, 08:12 PM
UrbanKnight
UrbanKnight's Avatar
This isn't meant as a dig, but why the use of a switch as opposed to using it the way it was designed?
I have one and love it on the road course....
Just curious on the button idea...
Old 04-27-2014, 09:24 PM
cyber-vette
The switch is to control when I want the throttle blip. The clutch switch control does not allow me that control. The throttle blip is not needed for every downshift IMO. I'll post my results when installed.
Old 04-27-2014, 10:34 PM
moose.b3
moose.b3's Avatar
Looking forward to your review.
Old 04-28-2014, 02:56 AM
db2xpert
db2xpert's Avatar
I have the auto-blip and it works great.
Still be interested to how your switch works, and your install.
Old 04-30-2014, 07:13 PM
cyber-vette
Finished building the harness. Clutch, Brake and Accel harnesses built with quick disconnects. More to come when the shifter switch gets here.
Old 05-06-2014, 09:12 PM
C5Z06CE
C5Z06CE's Avatar
I have it on my C5Z and it works great. As far as needing a button to control the blip mine is not connected to the clutch but to the shifter. So what that means is that when you want to shift and blip you move the shifter to the next LOWER gear and the blip is initiated. It does not occur with up shifts. No button needed since your shifter acts as the button. As long as foot is on brake AND clutch the blip is initiated. It seems you may be in the Tampa area. If you are interested go see my mechanic in Clearwater, FL. I can connect you up with him. He was the one that modified the Auto Blip with the manufacturer to make it work in a C5. I am certain he can do the same for the C6.
Not being mean or anything but it seems you are attempting to reinvent the wheel of sorts here. If you want it off for DD then turn off power to AutoBlip.
I hope this helps.
P.S. When I get it back from the shop (getting new diff and coil overs) I would happy to take you for a ride.
Old 05-06-2014, 09:44 PM
morris
morris's Avatar
I used it for 3 days at VIR this past weekend and it worked flawlessly with the standard setup. I guess if you are down shifting in the paddock I could see where you don't need it every time but on the track it seems to function properly as designed. I am at high rpms come to a braking zone and down shift the throttle blips to rev match and all is well. Even if I have to come down two gears it just blips twice for each.
Can you explain the scenario you are trying to customize its operation for, perhaps that will help me to understand
Old 05-06-2014, 10:24 PM
morris
morris's Avatar
here's a couple of minutes on the track where you can hear how it works
Old 05-07-2014, 12:13 AM
dapopa9
dapopa9's Avatar
Sounds like u were making phone calls while on the track. Haaa
Old 05-07-2014, 12:49 AM
w00tw00t
w00tw00t's Avatar
Why not just learn to heel-toe for all the effort you're going through? I practice on the streets and after a few months have finally gotten my heel-toe technique working well at the track
Old 05-07-2014, 11:04 AM
5280Racer
5280Racer's Avatar
interesting
Old 05-07-2014, 01:12 PM
Werks
Werks's Avatar
Blame it on the feet lol, in his case he got some big un's. Size 15 I believe, so it's too cramped for him to move them around under there.
To Throttle Blip Controller - Pivot 3-Drive BLP
Old 05-07-2014, 01:21 PM
gunluvS14
gunluvS14's Avatar
neat gadget but heel&toe banging down gears at the end of the straight is part of my enjoyment.
I have the same thought when slipper clutch became common on sportbikes, I like to blip my own throttle. If the rear wheel starting to back out at the corner entry, that's part of the fun
Old 05-07-2014, 02:23 PM
racerns
racerns's Avatar
Little off topic but do you have any video from group 3 from the past VIR weekend with the CG ZR1? I didn't run a camara this weekend. Thanks
Old 05-08-2014, 11:07 AM
cire96
cire96's Avatar
What w00tw said...Heal/toe is a critical part of the experience.
Cire
Quick Reply: Throttle Blip Controller - Pivot 3-Drive BLP
