When adding EOC, Ported Oil pump or OEM Z06?
I'm doing a cam swap and I wanted to install a new oil pump, even though the motor only has 67k on it... I will also be installing a large Setrab EOC with -12AN lines and I'm wondering if a ported oil pump would be a good idea? I'm thinking High Volume is not a good idea?
Former Vendor
You do not 100 percent need to do anything special. But adding a shim to a stock pump adds to the pressure output. Porting doesn't really make huge gains in pressure but will add to the volume a bit.
Is your current oil pressure good?
Randy
Randy
Current oil pressure is 27-29 at hot idle, 60+ at WOT. Since I have the whole motor torn down for the cam swap, I figured at the very least I should put a new (unmodified) oil pump in to replace the original. But I also was wondering, since I'm adding a few quarts to the system, if I should shim or port the new pump?
oil pump
Agree with Randy.
Unless you drill lifter trays and or use restricted pushrods you will just end up with more oil pooled in the heads with a high volume/high pressure pump.
I would use a new LS6 oil pump. Try to make sure it is appropriately centered before tightening bolts.
Agree with Randy.
I've had good experience with the LS4 high volume pump with the 42 psi relief. In my current motor I run restricted flow pushrods and drilled lifter trays but I didn't in my old motor. No isssues. Car never drops below 50 psi on track even in the summer heat. I run Amsoil 10w40 and a K&N racing filter.
Agree with Randy.
Increases oil return to the pan.
Are those just 1/4" holes? Does drilling the lifter trays affect lifter life or noise in any way? I will do that if it's a recommended modification. Let me know what other tricks you guys have that I should perform to the oiling system while I have it apart.
So far I have:
New LS7 lifters
New LS2 trays (plan to drill them)
New LS6 oil pump (unported, unshimmed)
So far I have:
New LS7 lifters
Former Vendor
No known problems with drilling the buckets. There has been some reported issues with batch number 10 on the lifter buckets. To the point if you have number 10's I would replace with new ones. Rare, but why not.
Randy
Randy
Premium Supporting Vendor
There are so many success stories out there about all our different setups, are there really any oil failure stories out there on an LS6 after an oil cooler install? It's almost like you can't go wrong with these no matter how much or how little money is spent on extras.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
Well... two of the guys racing LS6s out west have lost their engines already this year. Seems like both were seized bearings as from pictures it looks like rods came out the side of the block. So oil related failures will continue to be something I lose sleep over at the track.
OP, your current oil pressure sounds a little on the low side. I think it's a good idea to install a new oil pump whether you port/shim it or not. I wouldn't worry about the oil cooler needing more pressure. Just make sure you get a large cooler that can handle all the oil flow (sounds like you are).
It was a seized bearing, correct (rod rotated out of the engine - bottom in your case I think)? Assuming I'm correct, while I agree it really isn't directly an oiling issue (like loss of oil pressure), I would say it is oil related as oil is the film preventing metal to metal contact between your rod and the crank. Either way, seized bearings really scare me.
P.S. Really appreciate you posting all your info on your current NASA ST2 to SCCA T1 conversion. I'm going the other way (SCCA T2 to NASA ST2), but have my eye on going back someday (if the SCCA stops changing the rules every year which I can't afford to chase). My first race in NASA Apr 26-27 at Summit Point.
Well guys, I'm still debating my oil pump decision.
I've narrowed it down to:
GM LS4 pump ("newer" 42psi relief version)
Melling 10296 (which spring to install?)
Melling xxxx ? (some other Mellings, God there are so many to choose from)
GM LS6 unshimmed
GM LS6 shimmed
Would love to have someone make a decision for me lol.
GM LS6 unshimmed
GM LS6 shimmed
You would want the Melling 10295 standard volume as opposed to the 10296 high volume.
A ported LS6 is a good choice as it likely would not need to be pulled apart before install to clean out casting flash, which is necessary with any brand new Melling.
I emailed Doug at Precision Oil Pumps (www.precisionoilpumps.com) and got the following response:
Thanks for your interest in our LS Pumps. The larger volume pumps are a must for the external plumbing you have. Dont be scared it has been done more than you think. The only issue with the large volume pumps are the timing chain rubbing. It may need spaced and some grinding. Keep this extra work in mind. The 10296 is minimum choice or 10355
Thanks, Doug
Precision Oil Pumps
(559)325-3553
Thanks, Doug
Precision Oil Pumps
(559)325-3553
