Tire pressure help
Old 04-02-2014, 05:33 PM
63Corvette
63Corvette's Avatar
Default Tire pressure help
I need starting (cold) pressures for (real) scrub slicks for my STOCK 04 Z06. Also what to look for in pressure rise. Venue is MSR Cresson.
Thanks,
Old 04-02-2014, 11:02 PM
MarkDFW
MarkDFW's Avatar
Will depend slightly on the slicks you are running but I would start around 20 to 22 psi and target around 28 to 30 hot. Slicks need lower air pressure than r comps. 28 to 30 hot worked for me at MSR Cresson on Dunlop scrubs on the 3.1.
Old 04-03-2014, 07:35 AM
rfn026
rfn026's Avatar
I like to have 32 psi hot. That's on Goodyear DOT tires but folks tell me it works for almost all DOT tires. That means I usually start out with 22 psi cold. The best way to figure out the optimum hot tire pressure is to take temperature readings.
btw - The Sprint Cup guys were starting out at 14 psi a few weeks ago when they had big time tire problems. At 14 psi they were stupid fast - for a few laps.
Richard Newton
Car Tech Stuff
Old 04-03-2014, 02:54 PM
63Corvette
63Corvette's Avatar
Thanks Mark. I am in fact on Dunlop (4 year old) scrubs
To Tire pressure help
Quick Reply: Tire pressure help
