Has anyone cut out the rear inner fenders?
Old 04-10-2014, 10:37 AM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default Has anyone cut out the rear inner fenders?
My tires are about to do it for me...any ill effects?
Old 04-10-2014, 11:07 AM
2MCHPWR
2MCHPWR's Avatar
isn't it just the frame right behind the plastic inner liner? i guess if you remove the liner, you get 1/8" more clearance?
Old 04-10-2014, 11:13 AM
Bad Karma
Bad Karma's Avatar
I haven't; but I have a rough idea in my head (that could only work if I was running straight pipes) that the bottom of the rear inner fender could be modified to vent pressure back through the holes at the bottom of the rear bumper. Instead of pulling in the rear bumper like the C7R, of course the rear splitter is there directing air as well.
So, I'm curious to see where this goes.
Old 04-10-2014, 11:18 AM
RX-Ben
RX-Ben's Avatar
You will get an unhealthy hit in your lb/hp ratio if you ever compete in NASA. Otherwise, there are mini-tub kits available. It is just a fiberglass liner, nothing structural.
Old 04-10-2014, 11:24 AM
VGLNTE1
VGLNTE1's Avatar
Not the actual inner fender, just the plastic liner inside the wheel well. It's between the tire and the actual fiberglass fender
Old 04-10-2014, 11:47 AM
RX-Ben
RX-Ben's Avatar
Oh, that part is just decoration. No points hit either.
Old 04-10-2014, 12:23 PM
redtopz
redtopz's Avatar
The actual inner fender is part of the rear tub that sits on top of the frame and supports the rear quarter panels and rear bumper. The inner fender liners just keep mud and debris from the tires getting up into unwanted areas. I cut out a section of the inner fender liner adjacent to the frame rail on each side which provided I think about an extra 1/2" of tire clearance on the inside.
Old 04-10-2014, 08:11 PM
mountainbiker2
mountainbiker2's Avatar
If you take them out, you will get a lot of air caught in the rear bumper area.
Steve
Old 04-11-2014, 01:08 AM
Corvee
Corvee's Avatar
What springs are you running in the back of the car - stock leafs, coil-overs?
Old 04-11-2014, 09:29 AM
briannutter1
briannutter1's Avatar
Steve
Yeah, it would be better to mod one than take it out completely. The amount of rubber that will be shot over everything would be a mess.
Old 04-11-2014, 11:08 AM
Captain Buddha
Captain Buddha's Avatar
Mine self-removed (right rear on my old '13 Z06).
Old 04-11-2014, 04:35 PM
VGLNTE1
VGLNTE1's Avatar
Lg g2 coils. 700#s
VGLNTE1
VGLNTE1's Avatar
Ya, mines about there.
Old 04-11-2014, 11:55 PM
Corvee
Corvee's Avatar
Lg g2 coils. 700#s
If you are running aero you should consider going up on the springs. I have the same LG CO's and it corrected the problem.
Old 04-12-2014, 08:16 AM
Hi Volts Z06
Hi Volts Z06's Avatar
I actually removed mine because I used the space right behind the rear wheels for my trans and diff coolers. I installed stainless steel grill material over them to protect from rubber and rocks but essentially I have air flow through them and out the vents in the rear bumper.
Old 04-12-2014, 07:35 PM
VGLNTE1
VGLNTE1's Avatar
I gave LG specific mods and info on my car and they gave me 700/700. But yet I see cars with no aero with the same spring rates, so you just confirmed my questioning...what rate do you use?
Old 04-12-2014, 07:36 PM
VGLNTE1
VGLNTE1's Avatar
Did you add more holes to vent? That thing is a parachute
Old 04-13-2014, 01:31 PM
Hi Volts Z06
I didn't actually. My thought was with the restriction created by the coolers the amount of surface area for air flow was reduced and therefore the stock vents would be adequate.
I'm planning on doing a C7-R style diffuser later in the year so when I do that I might cut the lower portion of the rear bumper off so it will be a moot point.
Old 04-13-2014, 08:49 PM
Corvee
Corvee's Avatar
PM sent
To Has anyone cut out the rear inner fenders?
Quick Reply: Has anyone cut out the rear inner fenders?
