Installing harness
Old 04-10-2014, 08:41 PM
71corv
71corv's Avatar
St. Jude Donor '08
Default Installing harness
I received a set of harnesses for Christmas. Want to install in the C5 Z06. Would like to know what I need to do to retain the factory belts. I attend 3/4 events a year. Have the Corbeau seats. Still need to get a Hans device. Thanks
Gene
Old 04-10-2014, 10:41 PM
ZedO6
ZedO6's Avatar
Gene
This works pretty good
R-9115 Lap Belt Mount Kit - C5
http://www.bkauto.com/R_9115_Lap_Bel...5_p/r-9115.htm
Old 04-11-2014, 10:22 AM
Tim T
Tim T's Avatar
I've used these for years.
You will also need a shoulder harness bar
Old 04-11-2014, 09:15 PM
71corv
71corv's Avatar
St. Jude Donor '08
Zed06 and TimT, thanks for the help. Will have to get a set of these. Installed the bar way back when I got the car.
Gene
Old 04-16-2014, 09:45 PM
Chris Edwards
Chris Edwards's Avatar
Can anyone post up a pic of those brackets installed? I have a harness bar installed, and a harness (non clip style attachments) and I have a set of Hardbar seat bracket for Corbeau fixed back seats, these ones:
Before I rip into this thing, I'd like to figure out how to mount the harness. Do I need those BK brackets or can I just use the Hardbar seat brackets?
Old 04-17-2014, 03:22 AM
ImHuntingWabbits
ImHuntingWabbits's Avatar
My lap belts are attached to the brackets, but I've run in to a snag with the sub belts.
Apparently you can also mount them directly to the rails, but the eye bolts that came with my Schroth are 7/16" and thats too large for the M10 holes in the rails.
I'm currently trying to source a new eye bolt (Teamtech supposedly makes one but I'm confirming the size, part # is 2610 for the kit).
Edit:
I ended up just drilling the brackets to mount my sub belts. I'm not sure if this is really an ideal location but it works. An alternative would be to order a piece of 1/4" 6063 T6 bar (McMaster link) and drill that so the holes are a located a bit more towards the center.
Last edited by ImHuntingWabbits; 04-28-2014 at 03:50 AM. Reason: Add pictures for sub-belt attachments
Old 04-17-2014, 12:49 PM
skxf430
skxf430's Avatar
I use these for my harness in conjunction with the stock 3pt system.
http://www.vetteworksonline.net/cata...x.php?cPath=19
To Installing harness
Quick Reply: Installing harness
