ZFrog Rollcage build thread
This thread is about a rollcage build for my 02 Z06. I have tried to document all the major steps involved in building the cage as well as the design decisions as the information is spread about everywhere on various forums.
For the cage itself, there are some choices you can make but if you want to build an SCCA/NASA compliant cage, there are not that many options. I have attached pdf documents with the design options I have made for the cage (all pictures shamelessly taken from this forum or other places on the net!).
For starters, you need to gut the car. Here is a video showing the process of what is involved:
Some of the relevant threads for the various aspects of gutting the car:
- Dashboard removal: http://forums.corvetteforum.com/c5-t...d-install.html
- Steering wheel/airbag removal:
- Door panel removal: http://www.vetteessentials.com/instr...or_handle.html
- Sun visor removal: http://forums.corvetteforum.com/c5-t...placement.html
- Gas tank removal: http://forums.corvetteforum.com/c5-t...-come-out.html
- Evap canister removal: http://forums.corvetteforum.com/auto...-canister.html
Some good cage building threads:
- Rollcage and dash bar discussion: http://forums.corvetteforum.com/auto...-dash-bar.html
- Rollcage build thread: http://forums.corvetteforum.com/auto...-progress.html
- Door bars thread: http://forums.corvetteforum.com/auto...or-cage-2.html
- Windowless car & transport: http://forums.corvetteforum.com/auto...as-needed.html
I will update this thread as the cage build makes progress and also document the post-build tasks!
Last edited by lefrog; 04-14-2014 at 10:35 PM. Reason: Added link to windowless car & transport
Update 1
The door bars will have to go inside the doors and therefore I had to remove the doors and cut the panels.
The mounting plates are getting ready to be put on the car!
Here is the video:
Here is the video:
Nice progress! How'd you do your Forward bars? There's something weird about the pictures, almost looks like there's a joint near the top of the windshield in some pictures, but then they look continuous in others.
For the front bar, it just goes around the gauge console and the heater (note that the HUD won't fit anymore). Here is another view:
That picture helps a lot, I think the top of the A-pillar was overlapping the tube in your other pictures which made it confusing.
I'm in the same boat for carrying passengers, but I also want to maintain the center hardtop latch and a center bar would interfere. I'm not required to have anything up there but would like to do something now so I don't risk having to cut it up to do the install later. Is it SCCA that's requiring a bar in the halo?
Here are some updates. The cage is now completed, just added reinforcement bars from the door bars to the a-pillar bars:
A detail of what is happening behind the driver seat where the main hoop is attached:
Note the cut in the back to be able to brace the plate. Here is an outside view where you can see the cut in the fender well just on top of the frame:
On the passenger side, the diagonal was welded at the bottom of the frame and even with the bend it was in the way of the gas tank. Be careful to keep the area clear for the gas tank:
JN Phillips installed the new windshield for $221 (glass and install at home!):
For the windows, I made a simple clamp that I insert from the top of the door and just rest the window on it, it's super simple and works great. I'll put some more info after I shoot a video of it.
Here is how it looks like with the seats in:
Looks great!
One quick bit of constructive criticism, you should really think about mounting the bottom of your window net to the cage rather than the door, in a bad wreck when the net is needed it will easily pull the rivets out of the fiberglass door. The easy way to mount it to the cage is to run straps from the bottom mounting rod down and around the door bar, this gives you an adjustable solution without having to weld anything onto the cage.
Looks great!
As the door bar is really deep into the door, I have to find a safe routing for the straps without interference on the top of the door.
This is on top of my todo list with the kill switch wiring! Also cage padding needs to be done too!
