New Extremely Versatile C5/C6 Seat Mounting Bracket
Former Vendor
Pictures of our new prototype seat mounting bracket are below. We believe it will quickly be recognized as the most versatile, easiest to use system for installing aftermarket seats in a C5 or C6. Sliders can be mounted to it but even without them seats can be adjusted forward or back and in and out WHILE IN THE CAR. The floor bracket is slotted side to side and our custom side mounts front to rear, so the seat can be adjusted in any direction. The bolts we provide will keep the slots aligned so all you’ll need is a wrench to snug it down where needed. If multiple drivers use the car at a track but you prefer not to use sliders, this can be your answer. Loosen from under the seat, readjust and tighten.
We will test fit in a C6 soon but the goal is to provide a flat surface just above the carpet (with some massive wiring harnesses underneath that many hate having to relocate) for the seat to slide on. We have not added any o/e belt mounting points because the best position for them would depend on the seat used and positioning. A piece of angle iron or similar could easily be welded on from the underside of the bracket once you determine the best position. If we find a location that works in most cases we will build it into the bracket. More on that to come. We will have a package price that includes our new rear restraint mounting bracket below.
Former Vendor
The prototyped weighs about 17 lbs. We should be able to shave a pound or two but not much more. We are not going for lightweight with these, but strength and adjustability. We can already make a much lighter machined aluminum bracket for those in need, as shown below.
The belts are what hold the weight in a front impact. The brackets mostly need to survive the weight of the seat and not the weight of the driver. Someone please correct me if I'm wrong.
What would happen if you spun 180 degrees and hit the wall tail first? Belts won't help you there, that's the seats job.
Former Vendor
This will be just one bracket setup available. The base is designed to accept sliders and conventional side mounts (with the slots in the bottom going side to side). We are also having more machined aluminum brackets like above made.
We expect most of these items in July.
please advise when available. I am interested in going to a fixed bracket from my Arizen sliders. Need lap, sub (2), and stock belt attachment points for my application in a c5. Looks interesting, I'd prefer to see drilled holes in those side pieces for fwd/aft adjustment though I realize that negates your selling point of adjusting while seat is in the car. but that's not too important to me.
Very smart design.
However will you guys consider adding a row of locational pin holes? So the adjustable bracket won't solely rely on the tension force off the fasnters in the slots, rather it can take some shear load to a removeable locational pin; all we need is one tiny 8mm pin. Or at least use flanged type nut.
Looking good, what will be the price and avalibility?
Former Vendor
We should have them later this month. I submitted new drawings with seat belt adapters last week to the fabrication shop.
My thought was to take advantage of the adjustability of the bracket to position the seat in the car and then mark a location or two on the base where you can drill a hole for a grade 8 bolt or pin. It was difficult finding grade 8 carriage bolts and when we found them we had to buy 975 so we should be good for a while. The nuts we bought for the sample were flange type nuts.
Former Vendor
The base sits about ˝” above the carpet to help clear the wiring harnesses below. So the top of the base is about ľ” off the carpet. The next factor will be how the threaded inserts in each seat line up with the side mount holes. Seats can range between sitting on the base and up another ˝” or so.
We plan to make another bracket that is void in the center for our LX1 seat (something like our previous design).
The seat was designed for those needing to add headroom even when sliders are needed. The center drops 2” and can get close or to the carpet. We have a standard and wide version for C6’s. Only the standard version fits in a C5.
Former Vendor
Our website has been updated with the new mounting brackets. The description is on the product page but I have included pictures here as well.
http://www.marradind.com/proddetail.asp?prod=C56MBR
