Air compressor recommendation
Old 04-23-2014, 01:46 PM
TKOGTO
TKOGTO's Avatar
Default Air compressor recommendation
Not looking for commercial grade unit, just something with enough power to remove lug nuts. I have an impact wrench, a NitroCat 1200-K 1/2-Inch so good to go there. Any recommendations would be appreciated.
Old 04-23-2014, 02:06 PM
troyguitar
troyguitar's Avatar
I bought a decent size one at Harbor freight for $150 on sale and use it mainly to run my impact. 21 gal 2.5 hp 4.7 cfm@90 HF item 67847.
MR Turco
MR Turco's Avatar
I've had a 30 gallon craftsman for years that hasn't had an issue. Enough to do everything but continual grinding. If you really want to step it up, kobalt makes some decent 60gallon tanks a few of my buddies have that are oiled pumps.
Old 04-23-2014, 02:39 PM
AzMotorhead
Support Corvetteforum!
AzMotorhead's Avatar
Why not get a dewalt 1/2 drive 18v cordless impact?
Thats what I use on my sandrail. Alot less hassle than a compressor and hose
Old 04-23-2014, 02:51 PM
TKOGTO
TKOGTO's Avatar
Does it loosen your lug nuts?
I have a Ryobi 18v, 200ft lb rated, that does not.
Old 04-23-2014, 02:56 PM
ErnieN85
ErnieN85's Avatar
If that is what your using it for the Milwakee is the way to go
(pit gun)
Old 04-23-2014, 03:15 PM
troyguitar
troyguitar's Avatar
I have the Craftsman cordless that I take to the track and it removes lug nuts just barely, but it usually will not remove the caliper bracket bolts. Not a bad tool for mobile use but the air gun is a lot stronger for home use - plus an air compressor is frequently useful at home anyway.
Old 04-23-2014, 03:34 PM
FruiTay
FruiTay's Avatar
I am also in the market.
Old 04-23-2014, 05:24 PM
MySR71
MySR71's Avatar
Electric Cordless: Ingersoll Rand 7150. Works like a champ taking off lug nuts. Super easy but not cheap.
Air: I went with the Craftsman "Professional 27 Gallon Super Quiet Vertical Portable Air Compressor." At the time, it seemed to have the highest SCFM that I could find which used 120 Volts. Just wait for them to go on sale. It is only 150 PSI in the tank though so it does have to run a fair amount if you use it for grinding.
Old 04-23-2014, 06:40 PM
StKnoWhere
StKnoWhere's Avatar
Another vote for cordless impact tool. I have a Hitachi that will break them free but The low cost will work if you just loosen the lugs 1/4 turn before hitting them with the tool.
Old 04-23-2014, 07:11 PM
JDIllon
JDIllon's Avatar
Check out Northern Tool!! I got this one on sale for $399.00 plus $50.00 off coupon= Total $349.00 with free shipping. Plus they have rebuilt one with full warranty.
http://www.northerntool.com/shop/too...8765_200518765
One thing I wanted is one that was quiet!! The direct drive ones are really loud!!! JD
Note: you didn't say if you wanted it for the shop or pits?? If you get one for the pits, get one with at least a 6 gallon tank anything smaller will not run a air gun for very long. You can get a reconditioned one at NT for $99.00
http://www.northerntool.com/shop/too...5815_200405815
FruiTay
FruiTay's Avatar
Does anybody think this is a good deal?
http://seattle.craigslist.org/see/tls/4412546034.html
Old 04-23-2014, 09:15 PM
sperkins
sperkins's Avatar
Agreed. Same one I've used for years and yes it will remove lug nuts with ease many many times on a single charge. I haven't used my pneumatic air gun in forever. As a matter of fact, my 18V Dewalt is stronger than my Ingersol Rand impact at 110psi. No joke.
Old 04-23-2014, 11:17 PM
bags142
bags142's Avatar
I just got this from Lowe's
http://www.lowes.com/pd_518765-34252...ers&facetInfo=
On sale for $80...It's 1490 IN lbs, and I just used it to remove all 4 wheels lug nuts and both my front L/R brake caliper mounts.
This thing kicks A$$ for $80.
Old 04-23-2014, 11:21 PM
mgarfias
mgarfias's Avatar
I've got an 80gal/5hp ingersol rand. Its the ****.
Old 04-24-2014, 08:36 AM
lefrog
lefrog's Avatar
I have an Ingersol Rand SS5L5 that has a 100% duty cycle and is basically the most powerful you can get on 220V. It is a complete overkill for just an impact gun but I can sandblast and run all air tools continuously with it.
For impact guns, Harbor Freight has electric ones. A wired one for $50 and a cordless one for $120 (rated 330 ft.lbs - http://www.harborfreight.com/12-in-1...nch-60380.html ). I use the cordless one both at the track and in the shop and haven't used my air impact for a long while.
Old 04-24-2014, 11:19 AM
Bill32
Bill32's Avatar
Not really, That's a direct drive Craftsman. If you've ever heard one, they are loud, sounds like someone using an air chisel on sheet metal.
They will drive you out of your garage.
A belt drive compressor is 50% quieter.
To Air compressor recommendation
Old 04-24-2014, 11:30 AM
troyguitar
troyguitar's Avatar
This is why my compressor is in the basement with just a line running up to the garage. Saves space in the garage and makes it plenty quiet.
Old 04-24-2014, 12:29 PM
rfn026
rfn026's Avatar
Here's an article I wrote last year for Vintage Motorsport magazine. It covers the basic facts regarding compressors.
One nice thing we can do here in Florida is place the compressor outside of the shop. Then just plumb the lines into your garage or shop. Did I mention that I really hate the noise of a compressor?
Richard Newton
Old 04-24-2014, 01:12 PM
FruiTay
FruiTay's Avatar
Hey great input, thank you
Quick Reply: Air compressor recommendation
