Tegris and Splitters
Old 04-26-2014, 03:51 PM
rfn026
rfn026's Avatar
Default Tegris and Splitters
Here's an interesting article about using Tegris for the front splitter. It makes a lot more sense than carbon fiber.
Richard Newton
Old 04-26-2014, 10:27 PM
skxf430
skxf430's Avatar
Tegris is a very durable product. The downside is that it is heavy and is as expensive as carbon fiber.
Old 04-27-2014, 01:42 AM
OCCOMSRAZOR
OCCOMSRAZOR's Avatar
Richard Newton
I've used it and it works well. The trick to cost is searching for used NASCAR splitters that can be found really cheap.
Old 04-27-2014, 09:14 AM
bosco022
bosco022's Avatar
Trans Am 2 cars use aluminum clad PVC such as the brand name Komalu made by Kommerling USA. Works very well, is light and cost is only about 80 bucks for a 4x8 sheet. I had a tegris COT splitter on the Vette but have now changed over to the Komalu type.
Sign companies use this product most everyday, so they may be a local source.
Old 04-27-2014, 01:05 PM
crimlwC6
crimlwC6's Avatar
I was able to pick up four tegris COT splitters for about 200 bucks.
Old 04-27-2014, 01:35 PM
Hi Volts Z06
Hi Volts Z06's Avatar
After many failed attempts utilizing everything from 5/16" plywood with a resin coating to alumilite, I've found the best design is a thin aluminum sheet for the undertray with Tegris skid material on the bottom front edge. If you look on E-_ay there are lots of the old NASCAR pieces which are cheap, new and only take a little shaping to fit a C5 or C6. I will post a picture later or tomorrow.
This design gives maximum down force, excellent cooling (provided you've leaned the radiator forward and vented the hood) and a ton of downforce since there is zero deflection. I can literally rock the entire car with my hand if I push down on the splitter with my hand while it's on the lift. The downside is that it's a little heavy BUT if you've ever destroyed a splitter with a bad off you will appreciate the extra strength.
Old 04-27-2014, 02:53 PM
Bad_AX
Bad_AX's Avatar
What is involved in angling the radiator forward on a C6 Z06? I don't think I've seen anyone do this.
Old 04-28-2014, 12:45 AM
crimlwC6
crimlwC6's Avatar
Custom intake is about all it takes AFAIK. I did a c5 and saw a setup on a c6.
Old 04-28-2014, 08:25 PM
TLGunman
TLGunman's Avatar
Tegris and Jabroc both make good "consumable" splitter materials.
To Tegris and Splitters
Quick Reply: Tegris and Splitters
