I assume this won't work...
Old 04-29-2014, 02:13 AM
crimlwC6
crimlwC6's Avatar
Default I assume this won't work...
Has anyone setup a 15 inch wheel on a c5 for road racing so that the cheap bias ply tires could be used. If this idea is terrible, I blame beer. Could a steel 15 wheel be made so that racing on new slicks goes from 400 to 500 bucks a wheel to 600 bucks a set; that is the idea.
Old 04-29-2014, 04:42 AM
bosco022
bosco022's Avatar
It's the beer...the C5/C6 were designed by some pretty smart engineers to work with geometry/suspension designed for 17 & 18 inch radials. If you want pretty grippy 100 dollar tires buy some World Challenge take offs from some of the vendors here.
If you want the wonderful experience of pounding over curbs without upsetting the car, four wheel drifting through high speed corners, hanging the tail out while squealing with delight, get yourself an ex ASA GTA type car and go have a ball. Or even better if you got the bucks, build a TA2 Camaro or Mustang.
I am having Bemco build me a modern tube frame chassis, with a 1969 C3 roadster body , 600 HP SBC, Jerico tranny racer, so I can have my Corvette and Bias ply tire fix at the same time.
Seriously though, I think you can get some 15x10 Americans with 4 3/4 pattern. You could use Hoosier Modified tires 15x10 and 15x12, they are like 25" tall. Will they clear your brakes/suspension...that is the question. The better idea is the ASA car.
Old 04-29-2014, 06:33 AM
Gas Junkie
Gas Junkie's Avatar
The brakes won't fit within a 15 inch wheel.
Old 04-29-2014, 06:59 AM
millstreet
millstreet's Avatar
there's a reason the vehicular world moved away from bias ply tires 40+ years ago, radial tires work better. The GTA and TA2 classes use these tires as a limiting factor, to make the racing more driver centric, and less $ centric, Now beer, on the other hand, still works well
Andy
Old 04-29-2014, 11:45 AM
crimlwC6
crimlwC6's Avatar
Thanks!
To I assume this won't work...
Quick Reply: I assume this won't work...
