Autox on Square 285/18 Z2's?
In this thread
http://forums.corvetteforum.com/auto...-rivals-7.html
the Rival sounds like it isn't quite the right tire on a C5Z.
Has anybody tried running the current Z2 square 285/18's? Would it work better than a 275/18 (f) and 295/18 (r) Rival config?
In my case, either setup would not be daily driven.
I bet it would be pretty good since it is such a short tire at 24.8" tall. The 295 Rival is 26.1" tall giving you a very different ride height and effective gear ratio. It's like going from a 3.42 to a 3.60.
In this thread
I'm in the middle of installing a camber kit and VB&P 1100/800 lb/in springs. I'll have it aligned and corner balanced after that. Then I will play with swaybars some more after that. I'm thinking T1 bars may be too monstrous, but testing will tell.
Would this be for A Street? The Z2s can handle some pinching since they have stiffer sidewalls than a lot of other street tires, so I'd say it's worth a shot. I'm targeting 285 Z2s all around on 18x10.5 or 18x11 wheels for the STU C5, due to the gearing and I like how Z2s feel. Make sure you bring a water sprayer, they don't like to get hot!
