school me on brake fluid please
Received 1,984 Likes
I have done some track time and want to do more.
I have a C7 and from the race prepare section of the manual is the following exert:
Replace existing brake fluid with a qualified high performance brake fluid from a sealed container. Brake fluid with a dry boiling point >279°C (534°F) is qualified. If high performance brake fluid is used, replace it with GM approved brake fluid before driving on public roads. If high performance brake fluid is in the vehicle and the age of the brake fluid is over a month old or unknown, replace the brake fluid before track events and competitive driving. Do not use silicone or DOT-5 brake fluids.
So I know I need to go to a good DOT4 fluid.
But do I need to change it back to DOT3 after an event?
And I would think a good DOT 4 fluid would last a season..... here in Ohio maybe 6 months.
Finally what is the best way to change out the fluid? I've seen some pumps, bulb type bleeders etc. What is the easiest gizmo to buy to make the process easier??? Have someone pump up the brakes will get old I'd think.
Greg
Greg
No need to switch back to lame-o stock fluid after the event. If you're driving hard, the fluid probably won't last a season unless it's SRF. You can gravity bleed if you're patient and can't employ someone to work the brake pedal. Or you can buy a bleeder, but without a Tech II you won't get the fluid changed out in the ABS pump. Only way to kind of get around that is to find a slick surface to lock the tires on to get the ABS pump to cycle, then run home and bleed again. If you track regularly, you can get it all with a few flushes as my ABS would flutter at every track outing on small bumps and imperfections in the road. Now with the race car I just flat spot tires, but I'm getting better about it.
Here's an article I wrote a few years back. Some minor things have changed but the basics are all the same.
Richard Newton
Richard Newton
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
This will be fine until you have really aggressive pads, run full sessions and threshold brake every turn at near lap records. I even run it from time to time when I run low on the really good stuff.
http://www.autozone.com/autozone/acc...ier=33408_0_0_
Received 8,928 Likes
Greg
Greg
Bill
I use the Motive Power Bleeder. I'm not so sure about the ABS pump area, but I can change all the brake fluid in an hour or less (depending on my motivational level).
I drain the master reservoir (using a syringe), replace the fluid with new, then bleed the back calipers, refill the master, bleed the front two, then fill to the recommended level, test drive, double check the level, then load the car for the track.
http://www.motiveproducts.com
Why screw around? SRF!
Jim
Jim
Supporting Vendor
St. Jude Donor '11,'13
Full heartedly
CASTROL SRF
‘Typical’ New Dry Boiling Point = 310°C (590°F)
‘Wet’ E.R. (Equilibrium Reflux) Boiling Point = 270°C (518°F)
The ultimate racing brake fluid
Castrol SRF Brake Fluid's unique silicon ester technology absorbs less water than conventional glycol ether fluids and prevents the fluid's high temperature performance from deteriorating. Its wet boiling point of 270°C is vastly superior to the minimum requirement of 155°C demanded by the current US DOT 4 specification. Its ability to withstand temperatures in excess of 300°C and superior resistance to the effects of absorbed water have established Castrol SRF Brake Fluid as the world's premier fluid for the hydraulic brakes used in all forms of motorsport and racing.
CASTROL SRF
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Best bang for the buck is Amsoil 600 . Little better than ATE Super Blue . A click under the M brand but its half the cost .
Ive tried them all
You do not have to change back to dot 3
I do a quick bleed after every one or two track days . As needed
In a word NO . I can boils this crap in 3 laps
Ive tried them all
Ive tried them all
ATE Amber (was ATE Blue) is the minimum for track use. Cheap and easy to come by. I would never waste the labor to put anything less in a car that sees track duty.
If you're boiling your brake fluid in 3 laps you better check your brake temps. You're running pretty hot.
Richard Newton
Richard Newton
Gee ya think Mr . Newton ???
With a decent pad and good fluid I have no problem .
I was referring to the Valvoline dot3-4 that was posted . I ran a single piston caliper on my C4 for a while . I got a good feel for what fluid is track worthy.
Amsoil 580 F dry , 380wet . BTW ,I feel too much weight is put on wet . If you track it ,it should be changed out anyway , long before it gets saturated .
If you want a fluid with better numbers you have to spend almost 50% more .
Did the same lab verify those numbers ? probably not .
http://www.amsoil.com/shop/by-produc...?code=BF4SN-EA
Here is a little chart I have kept but haven't updated in a couple of years, so pricing may be off. I haven't seen any new fluid in a couple of years:
BRAKE FLUID COMPARISON CHART
Brand Wet Boiling Point Dry Boiling Point
Ferodo 1/2L 399*F 626*F $39.99
Castrol SRF L 518°F 590°F $68.95
ProSpeed 683 1/2L 439*F 683*F $39.99 MTI
Motul RBF600 1/2L 420°F 593°F $14.95
Motul RBF660 1/2L 401*F 617*F $28.95
AP-600 1/2L 410°F 572°F $19.95
ATE-Super Blue L 392°F 536°F $15.99
Valvoline 333°F 513°F
Castrol LMA 311°F 446°F
Ford HD 290°F 550°F
Wilwood 570 284°F 570°F
PFC-Z rated 284°F 550°F
AP-550 284°F 550°F
PFC 660 1/2L 383°F 617°F $39.95
Ford HD 290°F 550°F
AP-550 284°F 550°F
Ford HD 290°F 550°F
AP-550 284°F 550°F
Ford HD 290°F 550°F
AP-550 284°F 550°F
I have used both ATE fluids in my '87 as it's easy to see when the old fluid is out because of that color change. My '87 is not that fast and the local tracks aren't terribly hard on brakes. I have never boiled the ATE fluid; the car has C5 front calipers and stock C4 rear calipers.
I also use Speed Bleeders to do caliper bleeding/flushing. It's a one-person operation and I can easily bleed all 4 calipers by myself in about 15 minutes. A full flush takes longer but still it's an easy DIY operation.
The Motive bleeder is a good system, but it's best to just use it for pressurizing the M/C reservoir. The procedure that parsonsj mentions is a good way to do a fluid flush with the Motive unit.
Bleeding the ABS part of the system may take a scan tool to do if the ABS pump has to be energized to run fluid thru it.
Ive tried them all
Ive tried them all
In my TT car I've had it start to boil after 15 min - but only at Road Atl
Everywhere else - no problems.
SRF is the don't ever worry about replacing for a season.
No B. S. Chief , A few laps at 10/10s and I can cook the fluid, same with the ATE, just takes longer .(on a over the counter pad ) Even with Hawk Blues I can cook ATE on a long run if I get greedy .
I would not recommend a marginal fluid to someone new to the sport .May 3rd I saw four people who were new and had a brake issue . C5 ,911 , two Mustangs ...
People learning there cars and the track use more brake than they need .
Cars on street tires need more brake than a guy on R comps .
Blackhawk Farms is a stop and go track compared to Putnam .
The right pad is just as important as the fluid .
My 2 cents
My 2 cents
