Fluid change for HPDE
I changed oil and brake fluid to run at Road Atlanta in mid March...only ran 4 session one day.....I really hate to dump 8 quarts of $17/qrt synthetic with only 4 20 minute sessions...I'll be running at VIR next weekend. ..thoughts?
I also run castrol RBF.....sooo it's about 8 weeks old too...thoughts
I change after every event. brake fluid can go a bit longer especially if you aren't using slicks and hardcore brakes. but oil is cheap insurance. I would change it.
You don't need to change oil after one track day. Check level only. I change oil every 5 track days. I bleed brake fluid after 1 or 2 track days and change after 5 track days. Castrol SRF is good stuff. How hard are you running (what level group are you in)?
Here's my recommendation:
- If you run hard with stock oil cooling (or none), and oil temps get above 270+, I'd say change it after every event.
- If you have a proper oil cooler and stay below 260 the entire day, every 2 track events.
Like stated above....cheap insurance for your motor. Yes, it's $100 in oil or whatever your car uses, but that's cheaper than a $3,000 rebuild.
It's not a cheap sport.....so don't be cheap with maintenance.
Be cheap by not spending thousands on horsepower upgrades and spend the money on safety, maintenance, and track time.
You can buy a gallon of Full Synthetic Rotella T6 5W40 for $20 at Walmart and it will perform as well for track days. Many racers use it.
Mobil 1 0w40 synthetic "European Car Formula" works great in the C5's at least, $25 per 5 qt jug. Not sure if C6 uses the same oil.
Your SRF is almost definitely fine though, I wouldn't bother changing it. I'd just bleed it a little bit. SRF is expensive because it lasts longer than other brake fluids.
Former Vendor
Best advice right here. We get this all the time at the shop. And I usually go with the same line, "would you rather spend $100 on an oil change or $3000+ on a new engine...", they always choose the oil change. And like said above this sport is not cheap. We bleed and flush the fluid as soon as it begins to change color from the clear/amber to dark black. Also bleed and flush the clutch fluid at the same time. We also use Torque 700 on all shop and customer cars for brake and clutch fluid.
It is a huge waste of money to change your oil after every event !! I ran three events 18-20 sessions - 30 minutes each between changes. This amounts to 500-600 track miles typically. I performed a Blackstone analysis every other change along with the addative TBN analysis. Oil was always in good shape and capable of going several more events. Ran Mobil 1 5/30 and had a DRM oil cooler setup so temps were always below 240/250 deg. Temperature is the killer, if you don't have a cooler, GET ONE.
I change oil and filter after three events, (2 day events) if I run hard. Oil level check frequently and added if needed. I run 11 qts 5/50 Mobil One. Transmission and diff changed with additive twice a season, brake fluid monitored and changed depending upon sessions run, and clutch fluid withdrawn at resevior with rubber thingie and refilled at oil change and/or brake fluid change.
vz
vz
Thanks all for the advice. It's in line with Mobile 1 tech's advice. My car runs at 180 degf and the oil is clean. I would normally change it after 2 weekend track sessions, so I will change after VIR before I run another event.
Gasoline Addict
This must be a typo. You see 180F oil temps after running a hard HPDE session? Do you have an oil cooler? Even so, I'd expect you to see temps in the 250F range.
I regularly hit 290F in my 390whp C5Z when tracking hard and ambient temps are in the 75-80F range. I back off at that point and take a cool down lap. Plan to install an oil cooler eventually, to use track time more efficiently.
Usually change my oil after every event, using Walmart sourced Mobil 1 5W30. Blackstone analysis has shown the oil to be within acceptable range. Just bought European formula version of Mobil 1 and will try it out at Mid-Ohio this week and drain and send for analysis after I run one autox event on top on the track day.
Like others have said, fresh oil is cheap and easy to swap... engine rebuilds are not. If oil analysis shows the drained oil to be in good shape, I may do three events per fill.
I always siphon out and bleed old brake fluid after each event, as it is often cloudy. Use ATE DOT4 due to lower cost, but just swapped it out for Castrol SRF for the upcoming event later this week. Spongy and ineffective brakes at a track can kill you. Much more serious consequences than a blown motor, so worth extra attention, in my opinion.
I change oil every other track day. 10/40. My normal temps are around 220 oil and 220 coolant. Brakes I check pads after every event. I change fluid every season. I have a oil,tranny and diff coolers.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes
I run it for 2 events, 4 days and change.
I think you agree, no matter what you do with fluids, if you miss a shift then I guess it matters less what temp, oil condition, new or old, the cars are simply not made for the driver error. Sorry for your trouble at VIR, and I hope that the fix will be easy.
vz
Hello vz,
It was nice meeting you. Yes, I can only blame myself, but I'm amazed at how easy it went into reverse. I also learned that the same had happened to two other people I talked to with the Ford Racing Mustangs.....
Oh well, live and learn. I'm glad no one was hurt.
Hello vz,
I did manage to give some point bys, come to think about it, a bunch.
vz
