1/2 mi runway racing....
Received 1,679 Likes
Not AutoX but VERY fun none the less..... I found that I need a new hood... My flimsy Corvette Creationz hood didn't cut it... but at least I didn't break anything major...
Added 4 mph to my trap speed removing my hood....
I'd stay stock (mine was fine at 164mph, but the front/steering got very light) or get a heat extractor type so the air can vent out.
It did fold... Not a camera trick... 140 ish... and it buckled twice even after taping it down.
As I pulled into he pits it popped right back into shape... I just removed it altogether fr safety. stock hinges, locks..
I'm curious how the paint looked after it flexed back into its original position.
I've seen this happen a few times. I have the same style hood and my car has seen 180 numerous times and no problem. Where is the lift coming from to pack that much air under there? Did you remove the shroud or make a new one?
You hit on a good point. If you remove the seal at the windshield area, the high pressure area there would add to the pressure already under the hood.
