Pad Taper w/AP Racing Calipers on C5
Bumping this back up.
After 2 track weekends
Road America
Autobahn Country Club South Course
20 Heat Cycles Total
BBK: Essex Endurance Front kit
Tires: Hoosier R6
Pads: Carbotech XP24
This is only happening on both fronts. More on the inboard side then the outboard pad.
Pictures incoming
Road America
Tires: Hoosier R6
Pictures incoming
I have come to the conclusion the taper is from the spindle flexing.
I have gone the newer C6 ZR1 spindles and this problem is gone.
I did a track day yesterday. This was my first time out on my new AP Racing Endurance Kit (CP5060 caliper). They are tremendously better than stock. These 6-piston calipers also have varying sized pistons in them. They gradually get bigger in diameter with respect to direction of rotor rotation. This is supposed to minimize pad taper. I haven't had time to look at them yet. I'm now curious on how much the taper was reduced.
Supporting Vendor
St. Jude Donor '11,'13
Try flipping your inner and outer pads for more even wear.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
We can thank RX-Ben for identifying the part numbers in this post:
Part number is 88965637 and 88965638.
$160ish per new.
https://www.corvetteforum.com/forums...post1586457759
I have the old Hardbar AP T1 kit with SKF hubs, LG spindle ducts, ducting, on the stock C5 knuckles with stock rear calipers running XP20/XP10 pads.
My pads also taper just like that. I have since upgraded to the C6 knuckles but have not done a track day since to see if they still taper.
I just switch the pads around inbetween track events and they typically wear pretty evenly.
Received 8,928 Likes
The Wilwood SL6 calipers I had on my C5Z would taper the pads as well. They had different sized pistons that got larger in the direction of rotation but still tapered the pads.
One thing I did notice is even though the pads tapered I did not get the long pedal that happened when pads tapered in the stock floating caliper.
To reduce the tapering and to decrease wear I would flip the pads from side to side and I would use pad shims as they wore down. This worked well.
The W6A/W4A calipers I have on my C6Z taper the pads somewhat but they seem to cause more wear on the inboard pad than the outboard pad. Others have told me that is common on most opposed piston calipers but I didn't notice it on the SL6s.
Bill
Bill
#33
Another thing the makes my pads taper in the CP8350s -- Hawk brake pads! There is so much paint on the backing plate of a Hawk pad that it cooks off and builds up on the pistons. My upper pistons were much harder to move in and out of the bores than the lower pistons and this caused considerable taper.
Once I cleaned the pistons and replaced the seals, the taper got a lot better.
#35
Stupid paint. It makes a mess and interferes with taking thickness measurements. When prepping new pads I remove all the paint with paint stripper. I also scuff the mold release off the faces with an orbital sander so the pads start working sooner.
#36
$160ish per new.
$160ish per new.
#37
Isn't this part of the fact that the leading edge of the pad sees less heat than the trailing edge?
I get a little taper on my pads but just wrote it off to temperature differential.
#38
Race pads when run with high grip tires on high speed high grip tracks produce a sort of parallelogram style taper from the whole caliper torqueing under the load.
At first I was not sure if this was caused by a hub flex, spindle flex or caliper mount or some other cause. It all went away with stiffer spindles so draw your own conclusion.
#39
Jim.....just reread this thread and that is the funniest stuff I have read in here in a long time....!!!
I've been suffering the same pad taper issue for years, also suspect the spindles. I've tried all the "tricks" to get rid of it: new bearings, better rotors, replace spindle, rebuild calipers, better fluid, sacrifice a chicken, carve "oli is slow" into underneath his seat. None have improved the taper.
I've got a new set of the ZR1 splindles on the shop table awaiting install. Hopefully, I'll have some info on how they do by the end of the summer.
#40
