03 Z06 Autocross tire pressure ?
Old 05-20-2014, 12:31 AM
Dale760
Dale760's Avatar
Default 03 Z06 Autocross tire pressure ?
Hi guys
Though Im building a older 1980 at this time,
I just bought a cherry 2003 Z06 that is pretty much bone stock a couple weeks ago. It has a almost new set of FS Fire hawk wide ovals on it, stock size. 17s & 18s
I know I should run 30 to 31 psi cold for normal street use, but my question is what do you guys think I should run for autocross events
Im taking the car for its first solo event this weekend. I realize these are street tires, but a good baseline would be great to know
Thanks Dale
Old 05-20-2014, 12:46 AM
autoxer6
autoxer6's Avatar
35 front
32 rear
is a good place to start
Maybe 36 or 37 front if you dont have much camber.
Old 05-20-2014, 12:18 PM
Dale760
Dale760's Avatar
Originally Posted by autoxer6
35 front
32 rear
Thanks for the advice 6
The car is aligned to all the stock settings , so would you want to keep an eye on them and shoot for those pressures once up to temp
Cheers Dale
To 03 Z06 Autocross tire pressure ?
Quick Reply: 03 Z06 Autocross tire pressure ?
