1/8th clearance with Wiwoods and 18" Z06 wheels on front OK?
They are the narrow SL6s (7416 pads). I put them on and they clear, but it is close, like 1/8th of an inch. Don't know how much wheel flexes, if any, but there is not much room. I have some spacers if needed. Should I go ahead and put them on or does everyone just go with it?
I even overheated a set of BP20 pads and had no problems with all the extra heat that put out, and nothing expanded to have any clearance issues.
Former Vendor
Go with it. However...I'd urge you to check any alternative (stock) wheels you may have. Seen a few times over the years variations in castings creep in on things.
Received 8,919 Likes
Bill
Hubs are SKFs that are less than 2 yrs old.
However, when I switched my WW street rotor to my WW track rotors, the clearance is like 1/2" - ?????? The hats look the same and the rotors are the same size. Not sure what that is about, but definitely no concern now.
BTW - brakes are huge difference over stock. Took a couple of sessions to get used the extra stopping power. Actually, still stopping short at the end of the day.
