c5z oe ignition wires fail at 55k miles - video
This is what I found when I replaced them.
Skip to 1:50 for #4 wire
Skip to 10:20 for #4 plug.
Do you think the "marginal" wire conductivity caused the plug to load up with oil/unburned fuel?
Thanks.
I'll ask again in this thread, is there any vendor that makes a decent wire? No marketing BS magic spark yadayada wires.
Thanks.
Randy @ DRM told me to just use the OE wires. Which I would have done except for the dealer wanting to bend me over the counter with no lube. I basically swap wires with the plugs whenever I start to feel like I need new plugs.
AC Delco wires are fine if you add heat protection of some kind, I don't trust most of the aftermarket stuff. OE wires are know to go 100k+ in a street environment, heat is the only real difference in what the wires experience on the track.
That plug definitely got loaded up with crap if the wire was bad, a quick shot of carb or brake cleaner should fix it up if you're not replacing the plugs.
I believe there are some high performance (red) GM wires you can buy from Gene Culley or something of the like. Some additional heat protection like LateBreak posted is a good idea too.
Corvette spark plugs and ignition wires replace passenger side 2 4 6 8 by froggy - YouTube
Thanks.
Thanks.
Magnecore are the very best I have used them for three vettes now a over 100,000 miles each one and no failures (or crumbling)
a really good bet on #4 plug is the bad wire probably leaking spark for a while causing partial combustion. check that plug again after running the new ones for a while then you will know for sure.
BTW neat trick with the old end using it as an installer. if you use Magnecor you won't have that option as they don't fall apart (no old one to use)
Great video should be a big help for novices
Plug wires.
Received 8,928 Likes
You can buy a spark plug boot remover at most any parts store for just a couple of bucks. They clamp the metal housing and allow you to twist the wire and pull it off the plug.
Bill
Bill
