Valvoline synthetic DOT 4 brake fluid?
Anyone use this and a heavy braking track?
I used it at Sebring and had brake failure due to boiling the fluid. To be fair, I really don't think it was the fluid, I just think my mechanic did a poor job of flushing my system. After just 2 runs my fluid was dark like weak ice tea.
The price is sure right, does anyone use this with success??
I've used it at Pacific Raceways in my mustang and c5. Ran out of pad way before I had any fluid issues until I got up to hawk HP plus then just had heat related rotor cracks and pad wear.
Like it for the clutch as it is very clear.
Not so much for brakes at Sebring.
Probably not your mechanics fault. If the fluid was nasty before he flushed it, alot of the color will reappear very soon due to the new fluid leaching the lines and calipers clean even on the street. Takes several bleedings to get it very clean and to stay like that.
If you are decently hard on brakes at Sebring you will darken some fluid in your calipers just the nature of the beast, turn 7 is where I seem to kill mine. Normally flushed before a weekend and gave a quick caliper bleed after just to freshen.
When I went to slicks I boiled everything except SRF. On street tires I had good luck with Motul 600.
I run a '07 C6 base coupe with street tires, HP+ Hawk pads and brake duct cooling and spindle ducts. Run VIR, NJMP-L and SPM. My rotor temps are 450+ after a session.
Just remember the old saying " you get what you pay for".
Is saving a few dollars worth the risk of damaging your car and worse hurting yourself in a bad crash?
Many of you will agree/disagree with the advise I am going to give here, but being that I've been at this longer than 99% of you, I've got the experience to back up what I am going to say.
Use the best fluid you can buy! In my opinion, Castrol SRF is the best.
Good luck to all of you who decide to save a few dollars
I've been running the Valvoline Syn brake fluid for the past 15+ years for hi-speed track events and NASA TT
I've run it in a Camaro, Mustang, a CobaltSS, an LT4, an '03 Z06 and, currently, 2 seasons in a Miata, with several track records, all with NO BRAKE ISSUE's.
I'll continue using it
I boiled Motul 600 and Amsoil in my C5 Z with AP T1 kit before switching to Castrol SRF at Sebring.
Now, I can go an entire weekend or two without having to flush my brakes. With Motul I was flushing daily, sometimes twice.
Supporting Vendor
St. Jude Donor '11,'13
I would just go straight to SRF... Safety is not something to skimp on.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
The Superblue is hard to find now. Apparently our Lord, God and Master the federal government decided brake fluid can only be clear or amber. It was determined that using colored brake fluid could cause confusion and someone could confuse the blue brake fluid with some other fluid - no lie that is their reasoning.
I think God every day that we have Obama appointees making critical life safety decisions like this for us. I wonder how many lives will be saved by making blue brake fluid illegal?
Now that blue brake fluid is outlawed, only outlaws will use blue brake fluid.
I wonder - will there be blue brake fluid check points set up - for our own safety of course? Maybe they'll just combine the brake fluid and seatbelt checkpoints.
^ Hahah, thats an excellent reply and I agree with you 100%. Luckily our company ordered quite a few cans from Tire Rack prior to them running out. I got my hands on a couple, the rest flew out the door.
God willing, there will be check points set up, I will be arrested, convicted and sentenced to death. Clearly, I am a vigilante needs to be off the mean streets.
FWIW I have used the Valvoline stuff since it exists on the shelf at the Advance that is half a mile from my house and it did hold up on a road course with street tires for a weekend in my 4100 lb Audi S4. I also use the Valvoline in all of my street cars. When I have adequate time to prepare for the track, though, I use the ATE Type 200.
I know the amber is still available. A lot of people would switch between blue and amber each flush so you can make sure you flushed all the old fluid out without going overboard.
Received 8,928 Likes
I have been using Wilwood 600+ for the last couple of seasons with no issues. Worked fine at Sebring and VIR.
Bill
Bill
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Agreed. I know I need some brake ducting, I will work on that.
Also, I really don't think the brake fluid boiling was the fault of my mechanic, I think he tried, but just didn't get all the old fluid out. It was probably a combination of a pocket of crud and moisture that broke loose, with the ABS system not being bled out.
I appreciate the input everyone. Thank you.
