Rad hose laying on ECBM
I have a 01 Vette and I have noticed that the upper radiator hose is laying on top of the brake lines going to the ECBM. should I insulate the brake lines so that the heat from the radiator hose does not heat up the brake fluid ?
Former Vendor
Never a bad idea. But don't get too carried away. Also double check the hose to make sure it doesn't have any rub holes on it. Pumping water that hose moves around a bit. Not only that but the road is not kind.
Also try clocking it differently to pull it away.
Randy
Randy
