C4 power steering cooler
I am prepping a newly acquired 1993 C4 for track duty. It is equipped with the Z07 performance package, which I understand includes a power steering cooler. Being a new owner, I have no idea how the cooler is installed or how it's hose(s) is (are) routed.
I have read recommendations that the power steering hose should be upgraded to braided stainless steel, much like the more common brake hose upgrade.
Should I perform this upgrade? And if so, due to the PS cooler, do I need only one, or two hoses?
If your car has the PS cooler it will be located along the front cross memeber. It looks just like a radiator only much smaller. You'll want the upgraded line, I had mine fail twice. You only need one line, the high pressure line from the pump to the rack. It's not a tough change, but the attachments are hard to get to so you have to excercise patience...and turn the wrench like 1 degree each time.
I think I have one of the hoses if you need it. I'll check and let you know.
I agree get the DRM braided stainless steel power steering line. I had 2 failures of OEM type replacements in 1 month. The hoses did not fail, the o-rings did. Evidently not up to the higher rpm's. NO issues with the DRM hose.
where can i purchase these breaded lines and rings? I have just had my rack rebuilt and fluid is coming out of the top of the fluid canister. My car is strictly track use, only.
also need instructions advice on ducting the brakes
thanks
thanks
DRM = Doug Rippie Motorsports, look em up
Brake ducting - do a search, lots of pictures out there
