Brake pad chunking?
Brake pad chunking?
Anyone have any idea what would cause a pad to do this, notice the line scribed on the pad. They were a new set of pads I put on then ran 3 days at Road Atlanta, I didn't notice anything on the track. When I put the street tires on though I immediately started noticing vibration and sound from the effected wheel. I figure the pads have about 50% life left in them only this one was affected I am wondering if I can still use it and it will wear in correctly or if I should trash the set. Only this one padlet was affected like this.
The rotor seems fine by the way.
At Road A, the entry to 10a is pretty severe on pad temps. So is entry to T5, even though the duration is shorter than 10a. You have to bed-in properly and then sit for 24 hours afterwards or you'll risk chunking.
If that is your worst pad, you can get some more use out of them if you don't have any deep cracking. I would (lightly) knock the glaze off with the edge of a flat file.
For your next set, check with your supplier to see if you can get them pre-bedded, it helps.
Yea its a Cobalt pad made for a PFC Zrated brake setup. It is the only pad that appears to have had issues, I guess the pad will be okay but it does make a good bit of rotational noise when I turn to the right which puts lateral pressure on the drivers side rear which is wear the pad is located.
