Five point harness + head and neck system?
Gasoline Addict
How many on here use a head and neck system, such as HANS or Simpson Hybrid (etc) with their five point harness and race seat during HPDE?
I am going to start driving a car (C5Z) that has a race seat and harness (both seats), and was debating the health and safety aspect of using a head and neck restraint with it. Also, do some of you just (or additionally) use a side mounted nylon net?
The cost of the HANS device or similar product vs. its proven benefit is a no brainer, but I still wonder what people's thought process is behind their decision to use it or not to use it...
I am going to start driving a car (C5Z) that has a race seat and harness (both seats), and was debating the health and sanfety aspect of using a head and neck restraint with it. Also, do some of you just (or additionally) use a side mounted nylon net?
Gasoline Addict
What head and neck systems do you guys use and why?
My mistake, I should have used the term “head and neck restraining device".
I'm sure any device that passes the FIA standards will be acceptable.
http://www.fia.com/sites/default/fil...estraint_0.pdf
I purchased a HANS, as it was the "standard". Also, my LeMons team was using them, and it was easier that we all had the same anchors in our helmets.
In a 5/6 point harness you will not reach the airbag. With the added weight of a helmet on your head the forces your neck see in an impact are exponentially higher.
IIRC A 40 mph impact places ~ 1200 pounds of force on your neck while wearing a helmet.
Gasoline Addict
Yeah, I was familiar with the extreme forces generated during sudden stops, and those are especially true when your neck is burdened with additional pounds.
I found this write up that talks about various devices and their prefromance:
http://www.racedaysafety.com/whhenere.html
Yes I wear one as well. There is a school of thought that you should only use harnesses and a HANS in a fully caged car. Reason being if you rolled and the roof was crushed your head is basically locked in an upright position and would take that impact. I myself do not have a caged car so hope I don't have to test that ...
Received 8,928 Likes
This video is of a side impact but it shows how far the human body will move even when restrained by a race harness and a containment seat. The video shows a seemingly light brush with the wall and the driver's body moves over a foot. Same thing will happen in frontal impacts.
http://www.hmsmotorsport.com/docs/Wh...t_Side_Net.wmv
You really do want the harness to stretch since if it didn't the force of the impact would be dissipated in your body where really bad things could happen like tearing of the Aorta.
Bill
Gasoline Addict
Even with a 6 point harness a person can come into contact with a steering wheel mounted airbag. In a hit the harness stretches quite a bit. If you watch the slow motion videos of crash testing done with Schroth harnesses you can see the dummy's body gets very close to the steering wheel.
Bill
Bill
Bill
Bill
In a frontal hit, the Hans brand seems to be the gold standard. I have yet to see a convincing demonstration from the other manufacturers making a head and neck restraint that is as effective. But, I do hope there is better technology in the near future which incorporates a side impact.
HANS
Necksgen
HANS
Necksgen
I use the Defender which was the fore runner of the Nextgen. Get the Nextgen, it's more comfortable, as adjustable, and protects every bit as well.
Something commonly overlooked in HN restraint conversation is the importance of wearing the lightest helmet you can afford. Physical fitness is huge as well.
I also use the defnder. It also good side to side limitations and is fully adjustable for you and your harness system.
One thing I haven't seen in this string is the proper seat. The newer race seats are designed and built with a little extra room for the Head & neck restraint to fit properly. If you don't have the designed seat, the system will not work as designed.
Don't be cheap on safety !!
Gasoline Addict
It is great to see so much good input in this thread. I ended up getting a carbon fiber HANS device with quick release tethers and will report on its fit and feel (hopefully not function) next time I am out on track in a month or so.
Weight of the helmet is important too; I paid attention to it when I used to ride motorcycles, but somehow didn't do it for my racing bucket. Well... maybe next time, after this one expires.
