Oil cooler thermostat & cooler for C6Z road course discussion
Old 06-26-2014, 10:34 PM
  #41
Mark2009
Mark2009's Avatar
Mmm, no, I simply laid out the best case scenario for the stock setup. Without knowing some specifics we can't say if that scenario is accurate or not. However, we can pretty well say that even if the stock setup is functioning optimally it is still not doing enough for people that are driving really hard (i.e., 280F oil temp is too high).
But it does look like if you were to use the Setrab 172 unit you mentioned then the stock lines should be adequate (not trip the oil pressure bypass, unless it is calibrated to open at a lower delta-P than one would think). I believe someone here has that exact setup (Setrab 72 row with OEM lines) on a C6 Z06, hopefully they'll stumble across this thread and let us know how well it works.
Old 06-28-2014, 11:45 AM
  #42
ImprovedRacing
Supporting Vendor
ImprovedRacing's Avatar
Originally Posted by Mark2009
Great data from some posters, thanks!
This brings us to the question of pressure drop across the OEM cooler (and any aftermarket cooler that would replace/supplant it).
I ran across a graph at Earl's (Google Earls temp-a-cure) that shows their cooler (doesn't identify which one) compared to some others:
So, looking at some of those curves makes me wonder what the pressure drop is across the stock cooler and what the bypass setting is on the stock line/block adapter. Is all the oil getting thru the cooler or is some getting bypassed? This would tell us whether a better/bigger cooler alone can help.
I'm also having second thoughts about the two coolers in parallel idea I had earlier... if splitting the lines (T or Y) induces a pressure drop, would that induce cavitation in the line at that junction? (cavitation I presume would be bad... even if it reformed before re-entering the oil galley).
I don't know what "Cooler A" and "Cooler B" are in that chart, but the pressure drop across them is completely outrageous, even for a stacked plate cooler. 12 PSI at 2.5 GPM??? You'd barely have any oil pressure at 7 GPM. The curve for Earl's cooler is a little more typical but is still a little high as well. A typical stacked plate cooler should have around 3 PSI or less pressure drop at 5 GPM.
The Setrab 50-172-7612 is a great cooler and is very commonly used in Corvette applications. We've sold quite a few to Corvette owners.
Old 06-28-2014, 03:18 PM
  #43
parsonsj
parsonsj's Avatar
I see that the 6 series and 9 series coolers (50-660-7612, 50-948-7612) have higher BTU removal ratings. Why wouldn't one of them be a better choice (assuming a thermostat is used)? Is it a packaging issue?
Old 06-28-2014, 03:23 PM
  #44
ImprovedRacing
Supporting Vendor
They are have higher ratings because they are larger. The 72-row Series 1 is about the same size as the factory cooler, which is why it's a popular choice.
Old 06-28-2014, 06:38 PM
  #45
Mark2009
Mark2009's Avatar
I suspect the comparison to "Cooler A" and "Cooler B" will sell more oil coolers for Earl's than if they included the Setrab on the graph
Old 06-30-2014, 12:11 AM
  #46
parsonsj
parsonsj's Avatar
Anybody know what the BTU rating of the factory Z06 cooler might be? I count 42 plates, and it's roughly the same size as the 72 plate Setrab...
Old 06-30-2014, 10:46 AM
  #47
blkbrd69
blkbrd69's Avatar
The stock cooler looks more like a B&M transmission cooler than a true oil cooler.
They are ranked at 29, 000 BTU for about the same square surface inches. Of course every manufacturer rates them at different air flows, temperatures ext.... so hard to make a true comparison. I would bet the 172 is about twice the capacity.
What I would love to see is a 672, "no they don't make it". Thinking of trying the 660 as it is the widest available 6 series I can find, but would love to see it as a 72-75 plate full shroud width instead of the 60 plate.
Anyone have photos of a Setrab 660 or equivalent installed with a track report?
What track temperature drops have people seen going from stock C6Z to the Finspeed or Setrab 172 size?
Old 06-30-2014, 11:15 PM
  #48
parsonsj
parsonsj's Avatar
Factory cooler dimensions (in inches, +/- 1/16) :
Length: 23 5/16 (mounting boss to mounting boss)
Width: 6 1/4
Thickness: 1 1/4
Old 07-04-2014, 12:32 PM
  #49
parsonsj
parsonsj's Avatar
Here's some photos, first of the factory cooler next to the Setrab 172, and of the Improved Racing thermostat installed.
I've work to do to mount the cooler and route the plumbing (I use Goodridge 910 hose for most of my plumbing work).
Overall dimensions are very similar, but the Setrab has 72 plates to the OEM 42.
The Setrab is significantly thicker.
Plenty of header clearance. I don't see a need to shield the plumbing at these distances.
The thermostat fits nicely in the spot vacated by the OEM cooler adapter.
Old 07-04-2014, 04:35 PM
  #50
StKnoWhere
StKnoWhere's Avatar
For summer/track season, you can swap it out for a non-thermostat block.
Drift Vette (09-21-2021)
Old 07-04-2014, 05:01 PM
  #51
Dirty Howie
Dirty Howie's Avatar
Nice work
So you have to swap it out for track days. That wouldn't work for me as I would have to do it every month at least
DH
Old 07-04-2014, 07:16 PM
  #52
StKnoWhere
StKnoWhere's Avatar
The work was done by Craven Performance in St Charles, MO., awesome shop with an excellent GM tuner on staff.
The car is also my daily driver so I plan to leave the non-stat in in during track season and put the thermostat in (if needed) during the winter.
Old 07-04-2014, 09:51 PM
  #53
trackboss
trackboss's Avatar
If that setup does not pose some sort of restriction vs. a non-thermostat block there is no reason to replace it for track use.
Old 07-04-2014, 11:29 PM
  #54
blkbrd69
blkbrd69's Avatar
This is Florida. What is a season? Warm, Hot, Thunderstorm, Hot?
Curious why you ran the 180* fittings?
The Improved Racing thermostat passages don't seem to be a restriction, as the engine block passages are smaller. I like the idea of a 212*F.
Been busy with other projects. Finspeed wheels are here and an extra stock hood is sitting in the garage waiting to get cut for vents.
Old 07-04-2014, 11:44 PM
  #55
StKnoWhere
StKnoWhere's Avatar
Photo is before the LT headers went in, the 180's keeps the -10 lines inches away.
Old 07-05-2014, 02:29 AM
  #56
Dirty Howie
I am curious about you venting a stock hood. Please let me know or start a thread with pictures and track temp results. How much is this costing ?
And I'm jealous of the Finspeed wheels
DH
Old 07-05-2014, 04:39 AM
  #57
parsonsj
parsonsj's Avatar
Right. There's no need to ever remove it.
To Oil cooler thermostat & cooler for C6Z road course discussion
Old 07-05-2014, 11:07 AM
  #58
Pumba
Support Corvetteforum!
Pumba's Avatar
What is the size of the hole(s) in the block under this adapter?
Old 07-05-2014, 11:17 AM
  #59
blkbrd69
blkbrd69's Avatar
DH
Will be doing another thread with pictures of me cutting huge holes in a pretty like new hood and adding louvers when I get done. Probably 6 weeks out. Funny thing is my wife volunteered to cut???
Got a lucky break on the wheels. I couldn't be more impressed with the customer service or quality. Now have to find a local shop that will mount my Conti's.
Back to coolers. In about that same time frame hopefully parsonsj and myself will have close to the same setup but different size coolers to compare data on the same track at the same time. I like data and #'s.
Old 07-05-2014, 11:21 AM
  #60
blkbrd69
blkbrd69's Avatar
Keep in mind the oil passages in the block are only 13mm, which is about -8AN (1/2")
Hard to dispute the guy that actually designs these things.
Quick Reply: Oil cooler thermostat & cooler for C6Z road course discussion
