Help with rear wheel bearing / hub assembly
I need to replace my rear wheel hubs on a 2009 Z06, I know that Zr1 hubs are the way to go but as I look at the part on GMParts Direct There are several choices they are marked from FE1 to FE5 does anyone know which is the correct part to order?
If you want a ZR1 hub, FE5 is the correct one. FE1, FE3 are NOT ZR1. The FE5 ZR1 hub will fit your 09 Z06.
Ummm...yes they do. I have sold a few to my friends that wanted to upgrade.
Yea that's interesting I tried to install a set on my 09 two weeks ago it was a disaster. The traction control went berserk evidently GM changed the sensors between 08 and 09 , I have seen this documented in many places once I started looking for information.
http://forums.corvetteforum.com/1587115660-post8.html
