Suspension video
Suspension video
C6/Z06 at Road Atlanta, left front wheel, Pfadt Featherlight shock, 750 lb/inch spring, Pfadt heavy rate sway bar, Pfadt Control Arm Bushing Kit, Carbon Ceramic brakes. Road Atlanta is a reasonably smooth track but lots of elevation changes. Mostly right hand turns.
Got any GPS data that you could overlay to show the track position for the suspension movements?
Nice exposure quality. I did a similar thing with a first generation GoPro and it was a little too dark.
Gasoline Addict
I can't imagine putting a camera under my car, that'd be a death sentence when the green dropped!
The Mustangs always look odd when viewed at speed from behind. The outside of the inner tire always rides high like that, and even with a panhard rod something just looks off with the *** end too. The F bodies look normal and composed and the Corvettes are nowhere to be found, one little glimpse and they're gone. Except for the ones who can't drive.
Mustangs have a high rear roll center and a front roll center usually extremely close to the ground or underground. Pretty bad roll angle. Also notice how much the frame bends and the sway mount bends. Scary.
Gasoline Addict
