Camber Kits
Camber Kits
I have a question about purchasing a camber kit. I have a 03 ZO6 and the van steel kits say "steel frame". Is this the wrong kit to buy? If so what is the right one and do I need the upper and lower?
Thanks for any help,
Zach
Zach
I just bought this kit myself. You want the steel frame option as opposed to the C6 Z06 Aluminum frame kit. I bought both the upper and lower kit, which provides studs for the upper control arms that replace the stock bolts. This allows camber/castor adjustments on the top arms (setting the bottoms and leaving them with the lockouts) and not having to worry about cross threading the bolts into the frame each time you change the settings (assuming you are using the supplied washers). Hope this helps.
How are you guys adjusting caster up front? I have the Hardbar kit installed front and rear and I was also wondering if there is any way to adjust camber in the rear, or is it officially locked once the camber blocks are installed?
Never heard of anyone adjusting castor in the rear?
shims on front studs.
Last edited by blkbrd69; 07-15-2014 at 11:57 PM. Reason: Way late got to thinking castor?
just ordered
I just placed an order for the Van Steel alignment kit, top and bottom. I hope its here in time for my appointment with Phoenix Performance. It will be awesome to have the car set up by professionals.
Zach
Received 8,927 Likes
I had the Pfadt plates installed and then went with the Van Steel Plates. For the track I push the bolt holes all the way out and for the street I loosen the bolts flip the plates so the bolt holes are inward and thus get a minimal camber for tire wear, etc.
Bill
