Track Days with a C6 Automatic?
I was hoping to do some track days and was told that a stock (2012) C6 with an automatic would not do well here is SoCal at a track day. They will overheat quickly, especially if on a tight course due to the shifting requirements.
Can anyone tell share their experience with an Auto on the track or tell me if this is the case or what would be required to get the C6 capable of handling a track day in terms of heat management?
1 the biggest Trans cooler you can fit in ahead of the radiator.
2 if your a beginner that is it
3 if not.................
4. an engine oil cooler (Z06 lines and cooler work well) the next step would be a bigger radiator Dewitts (forum vendor) has one with EOC and a bigger trans cooler (that is what I use) along with the one in front of the AC condensor (in front of the radiator)
Brake cooling ducts and Spindle holders for them also
but the big thing is the trans cooler before any track time
Personally, I got tired of adding "Band-Aids" to try to keep it cool. I converted my A4 to an MN12 in January.
That's my story.
I have an 03 Coupe (heavily modified, H/C etc.) I had an aftermarket cooler (25-plate Setrab). It was fine when I first started to do track events. As I got better, the temps started to soar. Even with the external cooler I was still approaching 230 -240 trans fluid temp by the third session of the day. The PCM was shutting me down during my third run ("TRANS TEMP HIGH"). It stayed in OD and would not let me downshift manually.
That's my story.
That's my story.
you really need to be able to control that!
as for your 25 plate........... a 75 would be more like it
however if you want or need an automatic enough cooling can be had
At some point you'll want more cooling as has been suggested. But, go out and run the car and see how it reacts. Don't think you must have all the add-ons before you drive a track day. Don't push too hard or get stupid and you'll be fine.
--Dan
--Dan
I was able to manually D/S just fine... until it got hot and shutdown.
Go out and try, see how it works for you.
There are guys here in Florida that run the snot out of theirs and don't have any problems.
I almost killed mine and gave up.
Depends on the driver and the track.
Just so you know, an A6 auto is easier to go faster on track than an MN6.
Thanks....
I guess the new 8 speed "Track Certified" auto in a 2015 Z06 would solve the issue
In the meantime was getting a stick, but i drove the paddles and thought it would be so much easier for street driving in the SoCal traffic.... I did a few laps out at Willow in my GS, while I was at a track school (using their car), and in 6 laps my water was at 235 and my oil shot shot 285... when I saw those, I pitted and jumped in the school car to finish, and never looked at trans temps, but had no warnings. Ambient temp was hovering around 100.
I would like to track the car on occasion, and plan on water wetter and maybe a thicker Mobil One... and now add the trans cooler. I hoping to minimize the expenses until I plan on a more steady track regiment.
Sportbikes I have a 2007 C6 A6 base coupe with 77K and 20 HPDE track days. I've only had one trans flush done around the 35k mark.
Your car should have a trans cooler. This weekend at VIR with lows 90's at the track my trans temp was 240-250. The killer is my engine oil temp running at 280-300. Car has no oil cooler. I'm running 50W oil now for HPDE events.
Hope this link will work. Video of last weekend at VIR.
I just noticed that VIR is a much less taxing on the trans then Street of Willow... that might be to my disadvantage....
In case you haven't noticed, I'm trying to justify the new purchase
Sportbikes by all means upgrade to a manual Z06 or the 2015 z06 auto if your budget allows I would but I'm on a budget and to hip implants
I run Summit Point Main mostly and I've run at NJMP-Lighten and Thunderbolt once.
I spend my money on seat time and motel rooms
Thanks for posting the video.
if you have issues with a manual (but can afford to upgrade), you could always get a Z06, then install sequential gearbox (20 to 30k), or for about 12000 bucks just change the gearset to a dog setup, then get a mastershift system (either bump shifter or paddles)...
http://mastershift.com/new-street-manual.html
http://www.ppgearbox.com.au/page.asp?productid=107
My $0.02 - I instructed out at VIR a few years ago and my student had the c6 auto with paddle shifter and NO trans cooler.
In the afternoon - 2 laps and the trans would overheat and go into a different mode.
It was a little hairy going into south bend and having the car SHIFT in the middle of the turn.
So anyone that is gonna drive an auto on the track - get the best trans cooler you can find with plenty of air flow. And take a lap or two easy if the sessions are long.
Trackdaze VIR 7 13 2014 Blue Group 4th session - YouTube
a trans cooler isn't too hard to install, easier than an oil cooler and it is never a bad idea for auto guys.
so yeah a c6 auto is fine for hpde, monitor trans temps
With a Dewitts and dual fans installed I'm now at 244 oil, 190 coolant, and 216 trans temperatures driving it hard for 20 min.
Previously, Oil temps were hitting 290+ (309 once when not paying attention...) in less than 10 min previously.
A good tranny tune will help shifting a lot.
Delayed downshifts mid corner are always a risk so chose you shift points accordingly.
Laps using only 4/5 gear are good for focusing on compressing breaking zones and improving corner exit speeds, sort of Miata mode.
Your A-6 should hold up OK if you are on street tires and the engine is stock. I run my 12 GS A6 here in Florida (Sebring, Homestead, PBIR), if I don't use 2nd gear often temps will stay under 250. I changed trans fluid to Mobil 1 ATF as it has higher temp rating than stock GM ATF. I have more trouble with oil temps, I use Mobil 1 15W50 for HPDE. Have Royal Purple in rear diff.
I like A6, computer is much faster than me!
ok, here is what you need
Tranny cooler first then Dewitt's or Ron Davis radiator with integrated oil cooler
1 Post
if you plan on doing de events I would trade for a manual or buy something with the pdk dual clutch trannies. you'll save money in the long run.
I ate an auto tranny within 5 south Texas events back in the day...
