LT-1 extra oil??
Old 07-19-2014, 11:00 PM
emptnest
emptnest's Avatar
Default LT-1 extra oil??
Most of the track drivers of LS engine cars advise adding an extra qt of oil for track duty. Do the early and mid 90's LT-1's require extra oil too?
Related question - does anyone run a catch can on their LT-1?
Old 07-20-2014, 11:20 AM
Bill32
Bill32's Avatar
No and no.
Catch can, maybe if you were racing.
I've had no problems.
Old 07-20-2014, 11:29 AM
emptnest
emptnest's Avatar
Default Clarification
Yes - context of question is track duty.
Old 07-20-2014, 06:20 PM
Bill32
Bill32's Avatar
I've never put extra oil in my 92 to go on track and I've never used more than about 1/4 qt. by the end of the day.
Old 07-20-2014, 08:45 PM
emptnest
emptnest's Avatar
Good to know. Thanks!
Old 07-20-2014, 09:58 PM
96GS#007
96GS#007's Avatar
Received 1,745 Likes on 1,053 Posts
Sustained right-hand sweeper at Putnam Park ('94 LT1)....
Even with my Canton pan on my '96 LT4 (500+hp), I always overfilled by 1/2 qt.
Old 07-20-2014, 11:54 PM
Supercharged111
Supercharged111's Avatar
Every time I overfill my LT1 (93 Camaro CMC car) it blows it out in a session or 2. If I keep it factory full it burns less than half a quart per weekend on a clockwise track. Counterclockwise tracks not so much, but that's a valve cover issue.
Old 07-21-2014, 09:16 AM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I keept mine at factory fill and check it before each session.
Long sweepers are killer - spun the mains, no blow up.
So on goes a canton type road race pan. Hope to get it out of the shop this year
I miss it
Old 07-22-2014, 10:35 AM
autoxer6
autoxer6's Avatar
I overfilled mine about 1/4 quart. Much more than that and it spits oil in the breather.
Old 07-23-2014, 07:36 PM
FASTFATBOY
FASTFATBOY's Avatar
Overfill won't hurt anything. If you are worried put an Accusump on it.
Those pics of the scattered LT1 made me cringe.
Old 07-24-2014, 10:19 PM
emptnest
emptnest's Avatar
Thanks to all for sharing your ideas!
To LT-1 extra oil??
Quick Reply: LT-1 extra oil??
