Help identifying a C5/C6 swaybar
Anyone recognize this swaybar? No identifying marks of any kind. It's heavy so I assume it's solid, 1.25" diameter (T1 is 1.5"), and appears to have been gold annodized when new. I'm thinking it may be ADDCO? Hotchkis bars are usually black with a sticker in the middle.
My Addco 32 mm bar is black. I couldn't make it out on my device. Are the ends "crimped"? If so then it's probably a hollow bar and you could measure the thickness at the ends, divide by two and that's the wall thickness.
Al Chan
Al Chan
Ends don't appear "crimped" they appear to be flattened, but solid. The bar is really heavy... I assume it must be solid. I assumed Addco because if you google image search ADDCO corvette swaybar you see other bars in the same gold anodizing. My best guess is an older solid ADDCO 1.25". They make solid and hollow. Was hoping someone would recognize it.
